Radeon R9 270 with X1000 using Radeon 1.2 Driver
amigasociety
Post by amigasociety »
Am I correct that the new R9 270 cards work with the current 1.2 Driver?
I will update to 2.4 Driver once I get Amiga OS 4.1FE but for now want to use this new card.
I plan on using two cards and attempting the Dual Monitor setup on my X1000.
I have downloaded the Dual Monitor procedures from A-Eon but it talks about adding a second card but an older 9250.
My plans is to use my stock Radeon HD 4650 and the new R9 270 at the same time running two 27" displays.
Any advice would be welcome.
1st thing is first though.... does Radeon 1.2 driver support R9 270.
Also, do I follow the Dual Display A-Eon install and will that work with newer style cards too?
TJ
AmigaOne X5000
Amiga A1222 Tabor
Hans
Re: Radeon R9 270 with X1000 using Radeon 1.2 Driver
Post by Hans »
Yes, those cards will work with the version 1.2 driver.
Hans
Severin
Post by Severin »
amigasociety wrote:Am I correct that the new R9 270 cards work with the current 1.2 Driver?
Here's the two programs I mentioned in IRC:
Use dicpng from os4depot to extract them
