X-CAD XCAD on X1000?
Amiga-X
Post by Amiga-X »
Is anyone successfully running X-CAD on the X1000 platform? I am trying to run it and X-CAD reports it is an NTSC version only and shuts down. Tried all display modes and have not been able to overcome this issue. Suggestions/hints?
Thanks.
Once you've found the Needle..You don't need the Haystack !
joerg
Re: X-CAD XCAD on X1000?
Post by joerg »
Amiga-X wrote:Is anyone successfully running X-CAD on the X1000 platform? I am trying to run it and X-CAD reports it is an NTSC version only and shuts down. Tried all display modes and have not been able to overcome this issue. Suggestions/hints?
I don't know what X-CAD uses to check if the system is PAL or NTSC, but maybe changing SysBase->VBlankFrequency and PowerSupplyFrequency from 50 to 60 is enough to make it work. Or maybe GfxBase->DisplayFlags = (GfxBase->DisplayFlags & ~(PAL|REALLY_PAL)) | NTSC;
Amiga-X
Post by Amiga-X »
Thanks, joerg, I'll have to try that. I did get it running under E-UAE running WB3.1 after some minor config changes. Would be nice to get it working on native x1000, though.
