AllocVecTags
JosDuchIt
AllocVecTags
Post by JosDuchIt »
What AllocVecTags call would best replace
AllocMem(sizeof(struct Mystruct), 0);
would
AllocVecTags(sizeof(struct Mystruct), TAG_END) do ?
struct dos_info
	char *cb;			 /* copy buffer */
	LONG cbsize;		 /* size of copy buffer */
	BPTR rootlk;
	BPTR destlk;
	char rt[25600];		 /* root name, exagerrated length */
	char dest[25600];	 /* destination name, exagerrated length*/
	int  newpath, rootend, destend;
	LONG size;
	LONG protflag;
int main(void)  ///char *dirname)
  struct dos_info *ds;
if((ds=AllocVecTags(sizeof(struct dos_info),TAG_END)))
	Printf("size %d\n", sizeof(struct dos_info)); /// size 0
FreeVec (ds);
if((ds=AllocVecTags(sizeof(struct dos_info), AVT_Type, MEMF_SHARED, TAG_END)))
FreeVec (ds);
In the test i don't see a difference, but then i did not expect to have the Printf idenitfy a size of 0.
Is omething wrong with my test ?
Re: AllocVecTags
Post by thomasrapp »
You need to use %ld. %d is short word but the compiler puts long words on the stack.
JosDuchIt
Re: AllocVecTags
Post by JosDuchIt »
@thomasrapp
thanks.
