(Solved) Message structure of GM_HANDLESCROLL ?
TSK
Location: Home land of Santa C., sauna, sisu and salmiakki
Post by TSK »
What is the message structure GM_HANDLESCROLL receives in a BOOPSI class dispatcher ?
Keep the party going !
Re: Message structure of GM_HANDLESCROLL ?
Same as GM_HANDLEINPUT GM_GOACTIVE etc
TSK
Post by TSK »
So it's struct gpInput. But how do I get how much wheel was rotated and to which direction ?
Is that the best way to do it?
I use the IDCMP Hook function and collect IDCMP_EXTENDEDMOUSE messages. They appear as a struct IntuiMsg, which gives the data like this:
		case	IDCMP_EXTENDEDMOUSE:
			code = intuiMsg->Code;
			qual = intuiMsg->Qualifier;
		//	check that mouse is over the window and ignore if not
			if ((intuiMsg->MouseX < 0) ||
				(intuiMsg->MouseX > win->Window->Width) ||
				(intuiMsg->MouseY < 0) ||
				(intuiMsg->MouseY > win->Window->Height))
				break;
			wheelData = (struct IntuiWheelData *)intuiMsg->IAddress;
			if ((code == IMSGCODE_INTUIWHEELDATA) && (wheelData != NULL))
				deltaY = wheelData->WheelY;
(etc)
TSK wrote:So it's struct gpInput. But how do I get how much wheel was rotated and to which direction ?
Heres an incomplete fragment from a HandleInpt function.that should give a hint as to how to procede.
		switch(gpi->gpi_IEvent->ie_Class)
#if defined(__amigaos4__)
			case IECLASS_MOUSEWHEEL:
							if(gpi->gpi_IEvent->ie_Qualifier & (IEQUALIFIER_RSHIFT | IEQUALIFIER_LSHIFT))
								igd->igd_Top += gpi->gpi_IEvent->ie_Y *  ((struct Gadget *)o)->Height;
							else
								igd->igd_Top += gpi->gpi_IEvent->ie_Y * 8;
							if(igd->igd_Top < 0)
								igd->igd_Top = 0;
							if(igd->igd_Top + ((struct Gadget *)o)->Height > igd->igd_Height)
								igd->igd_Top = igd->igd_Height - ((struct Gadget *)o)->Height;
					retval = GMR_MEACTIVE;
				break;
#endif
tonyw wrote:Is that the best way to do it?
Definetly if you need to write a gadget that supports scrolling via the mouse wheel when being hovered over and not actually the active gadget.
If you are writing an app that needs to scroll an area independant of mouse posistion, then you way is good too.
TSK
Post by TSK »
@broadblues, tonyw
I got it working. I forgot I had the related code in my input handler already.
Thanks both of you !
