[Solved] GetCurrentDirName replacement.
AmiDARK
Post by AmiDARK »
Hello,
As the function is no more available in 53.30, does someone know a method to get the "current directory name" ?
Thank you.
Re: GetCurrentDirName replacement.
Post by thomasrapp »
NameFromLock (GetCurrentDir(),buffer,buffer_size);
AmiDARK
Post by AmiDARK »
Thank you thomasrapp.
I was not sure about this function.
Regards,
AmiDARK
salass00
Re: [Solved] GetCurrentDirName replacement.
Post by salass00 »
The GetCurrentDirName() function has just been renamed to GetCliCurrentDirName() (there is a compatibility macro in <dos/obsolete.h> as well) but because there are some problems with this function (see the dos.library autodoc) it is recommended to use GetCurrentDir() and DevNameFromLock() or NameFromLock() instead in new code.
