I just changed my code over to using IDoMethod() instead of IDoMethodA().
I notice the 16 bit X,Y values are coming through as 32 bit values.
The result is that X is coming through as 0 and Y is coming through as the X value in the passed msg.
eg.
struct ZM_FOLLOWMOUSE
..ULONG MethodID;
..struct Screen *zpfm_Screen;
..char *zpfm_PubScreenName;
..struct
....int16 ScreenX;
....int16 ScreenY;
..} zpfm_Mouse;
..struct Window *zpfm_Window;
struct Screen *pScreen;
struct Window *pWindow;
int16 iScreenMouseX, iScreenMouseY;
cb->cb_IIntuition->IDoMethod(pFeeder, ZM_FOLLOWMOUSE, pScreen,
cb->cb_PubScreenName, iScreenMouseX, iScreenMouseY, pWindow);
Is there a way to do this correctly. Or should I go just back to using IDoMethodA().
16bit values in IDoMethod()
Re: 16bit values in IDoMethod()
In general, all args passed to Amiga functions are passed as 32-bit values. So if you want to retrieve a 16-bit value, you must provide a 32-bit location where it can be stored by the function. This means that struct IBox and other 16-bit variables can not be used directly. You can pass 16-bit values, since the compiler will expand them to 32-bits, but getting them back means that you have to store them in a 32-bit variable, then read off the lower 16 bits of the returned value.
- gonegahgah
Cool, thanks Tony. I'll go back to using IDoMethodA().
You would think there would be some way to pass 16bit values on the stack via a function call.
Certainly the tag item functions need to pass everything as 32bit aligned but functions like IDoMethodA would be better to align on the arg types bit length.
I haven't looked enough into how to properly create a vararg function yet. Maybe it will make more sense to me then...
You can do it, but they have to occupy a full 32-bit longword for each arg, even if the high 16 bits are all zero.You would think there would be some way to pass 16bit values on the stack via a function call.
- gonegahgah
Just wondering...tonyw wrote:You can do it, but they have to occupy a full 32-bit longword for each arg, even if the high 16 bits are all zero.
When printf (and its many equivalents) pass arguments on the stack, do they align them all to 32 bit?
I know they use %d and %ld to differentiate. Would they need to differentiate if the arguments were all 32 bit aligned anyway?
- salass00
You could also just do:
cb->cb_PubScreenName, (iScreenMouseX << 16)|(iScreenMouseY), pWindow);
- gonegahgah
Thanks again salass.
That looks like it would work.
Even though their are no plans in the direction, I thought I read somewhere that we have to be careful with ended-ness when we code.
Does that solution present any problems in that respect or is it perfectly alternate future safe?
- salass00
It assumes a big endian CPU.gonegahgah wrote: Even though their are no plans in the direction, I thought I read somewhere that we have to be careful with ended-ness when we code.
For a little endian CPU (like x86) you would have to do:
cb->cb_PubScreenName, (iScreenMouseX)|(iScreenMouseY << 16), pWindow);
- gonegahgah
Cool. I'll probably avoid using that then.
