Locale OC_PreferExternal (correct bult-in strings)
javierdlr
Post by javierdlr »
Hi, I use to correct typos in my built-in strings the next piece of code:
  li.li_Catalog = ILocale->OpenCatalog(NULL, "poff.catalog",
                                       OC_BuiltInCodeSet, 3, // US-ASCII
                                       OC_PreferExternal, TRUE,
                                       TAG_END);
But I don't see (snoopy) that my program tries to load (in my case) spanish catalog and if none found then it should look for english catalog.
My Locale prefs has only SPANISH as Default languages table, should I add english/english-britsh?
TIA
abalaban
Re: Locale OC_PreferExternal (correct bult-in strings)
Post by abalaban »
Catalogs are cached in memory once loaded the first time. Try to look at the snoopy output after a fresh boot, you should be able to see disk accesses in Snoopy.
AmigaOne XE/G4
javierdlr
Post by javierdlr »
Changing it to:
                                       OC_BuiltInLanguage, "english",
                                       TAG_END);
works the way I want, if no spanish catalog found (and my Locale prefs default languages is: SPANISH, ENGLISH) it tries to load the catalog in '..catalogs/ENGLISH/poff.catalog'.
BTW shouldn't this be somekind of default behaviour, I mean without having in Locale prefs ENGLISH set?
javierdlr wrote:Changing it to:
                                       TAG_END);
It should default to checking the languages in the order specified in Locale prefs, and using the built-in strings otherwise. I don't see why English needs to be a permanent fixture, the built-in strings should take care of that regardless of whether there is even an English translation.
There is certainly a problem with Locale not picking the correct language, but I don't think it is relevant to your particular situation: http://forum.hyperion-entertainment.biz ... f=14&t=359
