Extra space char in french and german for FORMAT_DOS date
Post by zzd10h »
For my C programs, I use Date2Amiga with dat_Format FORMAT_DOS to display dates.
In french and german, there are extra blank characters at the end of date.
In the following picture, you can notice that
for french date, there are 2 extra blank characters before the last "XXX"
for german date, there are 1 extra blank character before the last "XXX"
for UK, italian, greek, spanish and swedisch, it looks goog.
http://zzd10h.amiga-ng.org/Divers/Bug_Date_FR_DE.jpg
executable to test (by changing your prefs/locale) and source code availables
http://zzd10h.amiga-ng.org/Divers/BugDate_FR.lha
is it just on my system (with french or german locales) or is it the same for you ?
Thank you
Guillaume
Re: Extra space char in french and german for FORMAT_DOS dat
Post by zzd10h »
Another french user has confirmed me the problem with my sample.
kas1e
Post by kas1e »
If you will write text of BZ (name of bz, body, all necessary info), i will add it.
Post by zzd10h »
Thank you Kas1e.
Isn't my post description and C sample with screenshot enough ?
Edit : If not, could you send me a bug report sample ?
abalaban
Post by abalaban »
@kas1e
Elwood or I will take care of investigating this further and reporting to the right component. I have very little time (to no time at all) myself until this week-end so if Elwood didn't reported it at that time I'll do it on Saturday.
AmigaOne XE/G4
kas1e
Post by kas1e »
@abalaban
Aha ok
@zzd10h
Let's wait one more week, if Abalaban and Elwood will have no time, i will help
Elwood
Post by Elwood »
Checked, confirmed and bug report filled, #8366
Philippe "Elwood" Ferrucci
Sam460 owner
AmigaOS 4 betatester
Post by zzd10h »
Thank you,
when using others formats for dat_Format, it's OK in french, no extra character at the end of string.
FORMAT_INT OK
FORMAT_USA OK
FORMAT_CDN OK
FORMAT_DEF OK
FORMAT_ISO OK
Post by zzd10h »
With Locale.library 53.6, newly available,
my problem of date format is solved.
Thank you !
