readdir() threadsafe?
Is the readdir() function in newlib.library threadsafe?
salass00
Re: readdir() threadsafe?
Post by salass00 »
chris wrote:Is the readdir() function in newlib.library threadsafe?
If you need thread safety you should use readdir_r() instead (or at least never call readdir() from more than one task at once).
edit: couldn't find readdir_r() in newlib or clib2 includes so I guess it doesn't exist. I could swear I had used it before but I was probably confusing it with strtok()/strtok_r(). I guess you'll have to either hope that readdir() is implemented in a threadsafe manner somehow or add some mutex locking around your directory scanning code.
edit 2: looking at the definition of DIR type (used by readdir()) I don't really see why it wouldn't be threadsafe (assuming that you don't access the same directory handle from more than one task of course):
struct __dir
   unsigned long numentries;
   unsigned long allocatedentries;
   unsigned long currententry;
   struct dirent *entries;
typedef struct __dir DIR;
struct __dir
Looking at that, as long as a simultaneous request for the same directory gets a different DIR pointer, I agree it should be fine.
Thanks.
@chris
It seems that newlib opendir() doesn't lock the directory so I wonder what happens when you opendir() a directory that gets deleted by another Process before you call readdir()?
xenic wrote:@chris
Hmm, good question. I guess it would return no entries. I would also expect readdir_r() to have the same problem.
@chris
I wrote a little test program for opendir() and the directory is locked and can't be deleted if the program is compiled with clib2. Since the underlying AmigaDOS functions Examine() & Exall() require a lock for input args and the new function ExamineDir() gets a lock on the directory when the context is created by ObtainDirContext() (according to the autodocs). If the AmigaDOS directory functions lock the directory so it can't disappear, it seems sort of sloppy that newlib doesn't do the same.
xenic wrote:@chris
That sounds like a bug in newlib.library.
DOS locks the directory as soon as anyone calls IDOS->ObtainDirContext() (that's what the Lock is for). There shouldn't be any contention between competing clients, no matter whether they come through a C lib or directly by calling IDOS->ExamineObject().
Newlib and clib don't have to lock anything, it's all done at a lower level.
tonyw wrote:DOS locks the directory as soon as anyone calls IDOS->ObtainDirContext() (that's what the Lock is for). There shouldn't be any contention between competing clients, no matter whether they come through a C lib or directly by calling IDOS->ExamineObject().
Did you read my post? I wrote a small program which calls opendir() on a directory and then waits for a Ctrl-C to closedir() and exit. While opendir() is still in effect (and supposedly locked as you state) I can delete the directory from another shell. If I compile the test program with clib2 then the directory can't be deleted from another shell while opendir() is in effect for that directlry. I would call being able to delete a directory while newlib opendir() is in effect a contention between 2 applications. I checked the sources for clib2 and it is in fact locking the directory when opendir() is performed; probably because it is using old OS3 AmigaDOS commands for directory and file access. If newlib opendir() is using new OS4 functions and calling IDOS->ObtainDirContext() (which supposedly locks the directory) then I shouldn't be able to delete the directory from another application until closedir() is called.
chris wrote:That sounds like a bug in newlib.library.
It would be interresting to see what happens if the directory is deleted after opendir() is called but before the first readdir().
