Hi to all,
Yesterday I installed my recently puchased copy of Quake II. After registration I downloaded the OS 4.1 Patch, but I have some troubles with the game...
Mi computer is a Sam440ep-Flex 800Mhz, Radeon 9250 128MB and SB Live, with OS 4.1 Update 2 installed.
Quake II starts, but AHI sound is too bad at 44.100... 11.025, also the game crashes at 1024x768.
What is the best config to play this great game under OS 4.1?
Thanks in advance for any help
Quake II - OS 4.1 Patch issues
Re: Quake II - OS 4.1 Patch issues
Hi again
Self solved.....
Setting WB at 1024x768 16 bit & AHI to 44.100, then, game started and.... a fantastic Quake II fully playable, smooth & fast...
The only issue I'm still having is with my USB Joystick Logitech Freedom 2.4 ... I cannot configure it to work under Quake 2....
Self solved.....
Peter Gordon
I can't remember offhand if the Quake 2 port supports joysticks. I'll check later and get back to you.merlinkv wrote:Hi again
Self solved.....![]()
Setting WB at 1024x768 16 bit & AHI to 44.100, then, game started and.... a fantastic Quake II fully playable, smooth & fast...![]()
