First keyboard press eaten...
cha05e90
Post by cha05e90 »
Hello,
I suppose this one might already reported somewhere, so just for the record: On my SAM440ep (mini), UBoot 1.3.1b, the first keyboard press (A-Eon AmigaOne USB keyboard) after booting OS4.1 Update 2 is "eaten"/ignored.
Re: First keyboard press eaten...
The same thing happens on my SAM Flex 800MZ OS4.1u2 also. It seems like it happens at other times too but I haven't been able to consistantly reproduce occurances after the initial reboot occurance. It's a minor problem for me.
CORRECTION: It's not the first key that gets eaten on my system. It I hold down the first character I enter after a reboot it doesn't repeat. The first char I enter after a boot or reboot won't repeat if the key is held down. Sorry for the erronious report in my initial response.
nubechecorre
Post by nubechecorre »
that bug happened also here on my sam, but then it disappeared.. i don't know why and how it disappeared but it did.. sorry no much help :(
http://www.os4games.it
Sam440ep mini-itx
Classic System:
Amiga 1200
Radeon 9250 128Mb VRam
Voodoo 3 3000 16Mb VRam
DVD-RW LG Dual Layer
SoundBlaster PCI 128
Cocolino Interface Elbox
AmigaOne White Mouse
Is this not an Issue with Uboot ?
Same thing happens when you enter the Uboot shell .
Elwood
Post by Elwood »
cha05e90 wrote:I suppose this one might already reported somewhere, so just for the record: On my SAM440ep (mini), UBoot 1.3.1b,...
Are you sure it's Uboot 1...b ? Version 1...d can be found here: http://www.acube-systems.biz/index.php? ... ware&pid=1
There was an OS4 bug reported and fixed in uhci.usbhcd 53.9
I checked and in Update2 there is no new uhci.usbhcd. Which version do you have?
Philippe "Elwood" Ferrucci
Sam460 owner
AmigaOS 4 betatester
14.System:> version System:Kickstart/uhci.usbhcd
uhci.usbhcd 53.7
fingus
Post by fingus »
cha05e90 wrote:Hello,
I can confirm it.
Olrick
Post by Olrick »
I used to have the same trouble but I didn't notice when it disappeared.
All I can say is that my uhci.usbhcd version is 53.7 and my Bios is 1.3.1d.
Have you checked your BIOS version ?
God grant me the Serenity to accept the things I cannot change; Courage to change the things I can; and Wisdom to know the difference.
cha05e90
Post by cha05e90 »
Elwood wrote:Are you sure it's Uboot 1...b ? Version 1...d can be found here: http://www.acube-systems.biz/index.php? ... ware&pid=1
My uhci.usbhcd version is 53.7. And, yes, I know there are newer UBoot versions, but I only flash a new version if I really, really have to. According to the readme's from ACube there seems no special fix for this "eat-first-keypress" problem present in UBoot - AFAIK.
If someone can confirm that a UBoot update will cure this problem, I'll consider it.
Its is gone with U-Boot 1.3.1d on a Sam flex. From the Uboot Shell and from OS 4.1 cli and from Notepad .
