Boot issue with Workbench disk
C64er
Post by C64er »
Hello all,
I downloaded my disk images and have created a disk set for OS 3.1.4.
When I try to boot from the Workbench disk (either from a disk or ADF file used with a Gotek drive) it goes to draw the Desktop and stalls. If I use the Install disk it'll boot fine. Is this normal for 3.1.4 or is my download bad?
Dan
Gulliver
Re: Boot issue with Workbench disk
Post by Gulliver »
Hi C64er,
Only the Install3.1.4 floppy disk is bootable now.
So it is okay, no need to worry.
C64er
Post by C64er »
Thanks Gulliver for the info, I feel better.
Dan
