Update 5 fails to boot
Lumby
Post by Lumby »
Hi all
After I have made a reinstall of OS4.1 update 5 I get stock at the boot screen!
My computer tries to boot but after 1 sek to 2 it restarts.
I Can also see my cyberstormPPC SCSI is back again?
It was disabled when installing OS4.1.2
I have tried 3 time got same result!!!! works up to update 4
My system is a A4000 CyberstormPPC 128mb
FastATA 7.0 ROM
CybervisionPPC
Xsurf
I have found out what there was wrong
startup-sequence
C:Bootloader COMMANDLINE "AllowBasepageAccess"
Was changed back to
C:Bootloader
Kickstart/Kicklayout-A4000
;MODULE Kickstart/cybppc.device.kmod
;MODULE Kickstart/cybppc.config
Was changed back to
Now everything works as it should ;-)
Best regards
danbeaver
Re: Update 5 fails to boot
Post by danbeaver »
New kernels will copy over the current kick layout file and require re-editing for specific needs.
