When I change AHI setup, (Frequency & Audio mode), the test noise is trashed until next soft reboot.
Instead of getting a simple "beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep" ... I got "bererererererererererererererererererererererep"
And any application that use AHI got the same result in their sound a hatched sound.
When I soft reset my AmigaOS 4.1 (all builds), the sound become good again.
Excepted that some sound mode don't work at all and always give a hatched sound.
Regards,
AmiDARK
AHI : Changing setting cause sound trashed
- javierdlr
Re: AHI : Changing setting cause sound trashed
what sound card do you have?
Here on my A1-XE & SBLive no problemas changing AHI prefs frequency/mode and clicking on test it sounds always beeeeeeeeep
Must be something special to your setup - I don't have this problem, be it my SAM440ep or Pegasos II. With both the beeeeep is perfect after fiddling around with the setting in AHI prefs...
