[Bad Glasses] Multiview not respecting ASL prefs (solved)
I could be completely wrong about this, but isn't Multiview using ASL requesters?
If yes than it's not respecting the ASL prefs in ENVARC:
I have set all ASL windows to appear in the middle of the screen
Position: Center on Screen
Width: 40%
Height: 75%
(all other options are blank)
yet Multiview keeps opening it's file requester on the top left
If no, what else can i do to make Multiview obey me? :-)
Thanks a lot
People are dying.
How dare you!
– Greta Thunberg
BillEaves
Re: [Bug] Multiview not respecting ASL prefs
Post by BillEaves »
You need to have the Override button enabled.
If not only applications which do not specify a position will use the prefs settings. With override, all ASL requesters will use your settings even when the application has already set its own.
Ah, thanks for that, exactly what i wanted :-D
Post #1 updated
People are dying.
How dare you!
– Greta Thunberg
