I recently bought a SAM 440ep-flex system, which I just re-installed Amiga OS4.1FE, with Update 1, and all was going OK, got the system working online, downloaded Update 1, and a few more updates like AmiSSL v4.7, and installed some other additions from OS4depot.
However, when I received it all it came with a Linux installation disc (v5.0.3 - Lenny) for the board, which was originally supplied by AmigaKit, but the CD it seems was an incomplete distribution of Linux Lenny as it got stuck/went no further close to the end of the installation where it was "setting clocks". It had not changed the UBoot system booting process so Amiga OS4.1 still booted OK, and I expected that if I installed Linux successfully it would not stop Amiga OS from booting but allow me an alternative OS to choose from.
Anyway, thinking along that train of thought, I donwloaded the "Debian_7.2_Sam440ep_Netinstall.iso" from here and expected it to boot/install correctly, but it kept asking for various files the CD didn't have, such as the 'Lenny' kernel files "zd1211/zd1211b_ub" and as it had installed some of the hard drive files it seems it had 'tinkered' with the UBoot boot mechanism, which I am not familiar with.
Now my system, won't boot to Amiga OS4.1FE or even to Linux as the installation did not complete successfully. So, so far it's just been a BIG MISTAKE !
Now I just get stuck at the UBoot screen which has been successfully updated to the latest UBoot (1.3.1g) released by ACube in December 2020 but I am now stuck after the initial options to select a boot option (Esc, Return, etc.) with ... a black boot screen with the wording ...
Parthenope (ub21b) version 0.91
No menu.1st or Kicklayout found!
Press a key to open U-Boot prompt!
What do I need to do to fix this situation so I can once again boot the system with Amiga OS4.1FE?
Hope to hear back from someone soon on this topic
Neil_P
SOLVED: No Amiga OS4.1FE booting - stuck in UBoot "limbo" after failed Linux installation
Re: No Amiga OS4.1FE booting - stuck in UBoot "limbo" after failed Linux installation
@ Neil_P
You have to boot from the AmigaOS4.1 CD and use System: Media Toolbox to reinstall the SLB, L:slb_v2 .
The Linux stuff is ancient and I can no longer support it as I no longer have the hardware .
Top
Top
I'm not sure how I am supposed to reinstall the SLB - whatever that is/please explain (possible explanation/acronym meaning SLB - Secure Loader Block - used in computing) - by using the file in the "L" directory slb_v2 - which I have located but I don't know what to do with it using Media Toolbox as that's the HDD formatting tool as far as I know so how does that affect UBoot so that it resets the system to boot from the HDD?Spectre660 wrote: ↑Wed Dec 23, 2020 1:24 pm You have to boot from the AmigaOS4.1 CD and use System: Media Toolbox to reinstall the SLB, L:slb_v2 .
As far as I know it's in UBoot that the Linux installation affected the booting process and has my system halted at that point. I can boot with the OS4.1FE Boot CD but I can't use my system properly as the CD only loads the basic system and then has issues if you try to do much more with it, and tries to reboot at every opportunity it can, as I'm sure you know.
That's all very well for you, but some of the files are accessible on these forum pages and that's what has got me into this mess in the first place, and I seem to remember they were made available by you, so you have some responsibility for them being incomplete in the first place.Spectre660: The Linux stuff is ancient and I can no longer support it as I no longer have the hardware .
That's not to say that I shouldn't appreciate you picking up on my situation and offering your advice - which I really do very much appreciate.
@Neil_P
Sam440ep Os4.1 installation guide in pdf. Page 2 .
https://www.google.com/url?sa=t&rct=j&q ... KzoyiqCCG4
Aha! ...Spectre660 wrote: ↑Wed Dec 23, 2020 5:13 pm
Sam440ep Os4.1 installation guide in pdf. Page 2 . https://www.google.com/url?sa=t&rct=j&q ... KzoyiqCCG4
In fact the re-installation of OS4.1FE and update v1 has got the USB system working at the moment, at least the ones I have connected through the Belkin 7 port USB hub, so that's a big improvement as well,
Without your help I would have had a miserable Christmas wondering how to get it resolved - so have yourself some heart-felt Merry Christmas wishes from me.
Re: SOLVED: No Amiga OS4.1FE booting - stuck in UBoot "limbo" after failed Linux installation
@ Neil_P
You are welcome.
Thank you and a Merry Christmas to you too .
You are welcome.
