Update 3 RoadShow Prefs crash
samo79
Post by samo79 »
Hi, i make a clean install and now i need to re-activate the internet connection on my Sam Flex
My Amiga is connected to a cable with a standard router, base internet connection is on my second Windows XP PC (as always)
I go into the Internet setup and i set on "Interface":
Name: The name of my connection
Gesture: ppc440ep_eth.device
Unit: 0
Type: Ethernet
But i can be able to connect using Update 3
But the reason why i open this thread isn't this:
As it doesn't work i try modify the connection prefs setting "Unit 1" instead (i didn't sure in witch port the cable was plugged) but after a while I get a RoadShow Prefs crash and then a Recoverable Alert (witch i can't be able to skip manually using the mouse because USB mouse are not supported on Sam when such Recoverable alert happen !)
Here the crash:
Crash log for task "ROADSHOW_PREFS"
Generated by GrimReaper 53.2
Crash occured in module ISO-8859-15.charset at address 0x6FF641EC
Register dump:
0: 0003FFF3 55716BB0 00000000 58CD9A20 00000008 5444BFD8 FFFFFFFF 00000000
8: 58D30288 58D30000 56D75CA0 5FFB5CCC 44424022 00000000 53920000 8003000E
16: 53F673B0 53920000 53920000 00000008 00000001 53920000 53927020 53920000
24: 00000000 FFFFFFFF 56D7CBA8 53927020 14FA21E0 53920000 5444BFD8 00000008
0: nan 1218 673 34
4: 0 51.8 0.8 288
8: 201 2.78132e-309 594.8 255
12: 1 674 0 -5.05923e-321
16: 1.32625e-315 0 0 0
20: 0 0 0 8.88967e+20
24: 4.94066e-324 0 0 -1.20437e+36
28: 0 1.35808e-312 8.8275e-311 1.78006e-307
Machine State (msr) : 0x0002F030
Condition (cr) : 0x84424028
Instruction Pointer (ip) : 0x6FF641EC
Xtended Exception (xer) : 0x20000007
Count (ctr) : 0xFFFFFFFF
Link (lr) : 0x6FFF69F8
DSI Status (dsisr) : 0x00000000
Data Address (dar) : 0x00000008
680x0 emulated registers:
FPU0: 0 0 0 0
FPU4: 0 0 0 0
Symbol info:
Instruction pointer 0x6FF641EC belongs to module "ISO-8859-15.charset" (HUNK/Kickstart)
Stack trace:
module LOCALE:CharSets/ISO-8859-15.charset at 0x6FF641EC (section 4 @ 0x1CC)
module LIBS:locale.library at 0x6FFFC828 (section 5 @ 0xA808)
module Internet at 0x6FD4C3DC (section 5 @ 0xF3BC)
module Internet at 0x6FD4EEBC (section 5 @ 0x11E9C)
module Internet at 0x6FD4388C (section 5 @ 0x686C)
Internet:_start()+0x54 (section 1 @ 0x69c0)
native kernel module dos.library.kmod+0x00020a14
native kernel module kernel+0x0003af4c
native kernel module kernel+0x0003afcc
PPC disassembly:
6ff641e4: 39090188 addi r8,r9,392
6ff641e8: 7cc903a6 mtctr r6
*6ff641ec: 88040000 lbz r0,0(r4)
6ff641f0: 38840001 addi r4,r4,1
6ff641f4: 89250000 lbz r9,0(r5)
System information:
CPU
Model: AMCC PPC440EP V1.3
CPU speed: 799 MHz
FSB speed: 133 MHz
Extensions:
Machine
Machine name: Sam440EP
Memory: 1048576 KB
Extensions: bus.pci
AFAIK I never seen such issue with the Update 2, anyone with similar problems ?
Now i retry to connect my Sam, crossing finger ...
samo79
Re: Update 3 RoadShow Prefs crash
Post by samo79 »
Ok i think to have found the reason of the crash !
On latest update 3 we have the old italian keymap (i think about it only reading carefully the crashlog) so i just change the old one with the latest italian keymap created by Lecta and now it doesn't crash anymore changing the port on the fly
This is the new file
http://www.sguidetti.net/wp-content/upl ... keymap.zip
I need some more test of course, also i need to reactivate my connection but for now no luck :roll:
Lecta
Post by Lecta »
That's very strange,
the only change I made to the keymap was the rawkey code of "ù" key from "2B" to "0D"...
samo79
Post by samo79 »
@Lecta
Yep, it's a bit strange indeed but now it seems solid (it's a beast for betatester!), aniway for future updates i really hope to see all your localizations included, we also miss the italian locale for the popupmenu, it's annoying to install again and again all such files manually :roll:
samo79
Post by samo79 »
@Devs
About the GrimReaper is it possible to fix, I mean, is there any "tricks" to avoid the crash ?
