Update 3 + uA1c problem
VooDoo
Post by VooDoo »
Heya ppl...First need to say thanx for this update and hard work on it..
After installing this update have some problem..
Yam and IBrowse is not working anymore.. DSI error all the time when try to strat it..
Reseting via ctrl + a + a (USB logitech keyboard) is not working OK,after using this combination AmigaOS is reseting and get in AmigaDOS not loading WB..But when using reset option from Reboot system menu all is ok!
For now have only this problem,get testing.
Thanx for helping..
My config : uA1c + 256 mb
davebraco
Re: Update 3 + uA1c problem
Post by davebraco »
Did you try with another USB keyboard?
I try with an apple pro and a Z Merc keyboard and I don't have any problem in reseting the Amiga OS on the µA1.
About YAM and iBrowse you could check this post :
http://forum.hyperion-entertainment.biz ... f=14&t=271
VooDoo
Post by VooDoo »
davebraco wrote:Did you try with another USB keyboard?
Now try old PS2 keyboard and resting is OK.Dont know where is problem wiht Logitech keyboard, all buttons is working OK , only when reseting have strange situation ..after resting AmigaOS get in DOS not loading WB.. like some startup problem?
