I can make a hotkey with both plain + and numpad + . I can use neither plain - nor numeric key - . There's probably a good reason for this?
edit: on a PC keyboard the plain - is near rcommand on some keymaps, but this consideration doesn't apply to the upper right corner minus.
FKey +-
FKey +-
* AmigaOneXE 750FX 512+0 MB RAM, Radeon 9200, sii3112ide, DVDRW ~ AmigaOS 4.1 Final
Re: FKey +-
Hi Thematic,
Looks like minus is FKey's special control character. If you define a hot key with the following key sequence, numpad's minus key should work: NUMPAD --
To make the main keyboard's minus key to work, try this key sequence: --
Maybe one of the developers can shed more light on this matter.
- Janne Peräaho
Re: FKey +-
Thanks! Maybe FKey could just use the escape method - that it seems to be - when you define the keys by clicking 'learn' and pressing them?Spektro wrote: Looks like minus is FKey's special control character. If you define a hot key with the following key sequence, numpad's minus key should work: NUMPAD --
