Shell copy-command
mlehto
Shell copy-command
Post by mlehto »
Copy command from shell.
COPY somefile AS someotherfile
produces error : cannot open "AS" - Copy: object not found.
Produces anyway drawer without icon named someotherfile wich have somefile inside.
Same as I try to rename somename.info
Dont know if this is more or less as intended.
No Idea, where I got that AS , maybe from WB 1.2/1.3 wich Im not used over twenty years... ? Or solely from my own head.
salass00
Re: Shell copy-command
Post by salass00 »
@mlehto
The rename command has AS as a synonym for the TO argument so you can do:
RENAME somefile AS someotherfile
Maybe this is what you remember and have simply confused the rename and copy commands?
mlehto
Post by mlehto »
Most likely.
Is that copy command behauvior intended ? It is somehow handy ... :)
I got grim today, some kernel module get stack overflow. Is someone intrested in crash log ?
salass00
Post by salass00 »
mlehto wrote:Most likely.
You're telling it to copy the files "somefile" and "AS" to a directory named "someotherfile" so the behavior is not really unexpected.
Maybe you could post it here and we can say if it's interesting or not after looking at it? Also was there anything specific you did to cause it?
The Copy command's template is:
FROM/M,TO/A,ALL/S,Q=QUIET/S,BUF=BUFFER/K/N,CLONE/S,DATES/S,NOPRO=NOPROTECTION/S,COM=COMMENT/S,NOREQ=NOREQUESTERS/S,NOREP=NOREPLACE/S,INTER=INTERACTIVE/S,FORCE/S,ARC=ARCHIVE/S,NEWER/S,COPYLINKS/S,FOLLOWLINKS/S
There is no "AS" option in that list.
mlehto
Post by mlehto »
I played around internet with OWB. Crashlog says OWB. Intresting part was, that stack was outside bounds. Stack itself says kernel module. After crash I made soft reset and machine freezed while after that. So I think that it may be kernel module. Wich were first or cause, dont know, Im not expert with crashlogs.
System is fresh install with very little tweaking. Works pretty fine now...
Here anyway.
Crash log for task "OWB"
Generated by GrimReaper 53.16
Crash occured in module  at address 0x00000000
Type of crash: ISI (Instruction Storage Interrupt) exception
Register dump:
   0: 0180DB20 020991E0 00000000 020A2BEC 021D0F48 02099210 00000023 020A2BEC
   8: 0183C928 00000000 54C45B78 00000100 00000794 65C4A740 00000000 65C42B08
  16: 65C443C8 65C42B64 DEAD0077 65C443C8 661C0000 65AD7C78 6582A024 65C42B64
  24: 65AD7C78 6582A024 020A2BEC 02099210 020A31EC 021B69A6 00FFFF00 00000000
   0:              nan                0                0                0
   4:               -2               -3              475              475
   8:               -2               33               -2              806
  12:              323      1.38962e+09                0                0
  16:                0                0                0                0
  20:                0                0                0                0
  24:                0                0                0                0
  28:                0                0      1.38962e+09      1.38962e+09
FPSCR (Floating Point Status and Control Register): 0xA7202100
           Machine State (msr) : 0x10003032
                Condition (cr) : 0x5297B390
      Instruction Pointer (ip) : 0x00000000
       Xtended Exception (xer) : 0x01829310
                   Count (ctr) : 0x00000000
                     Link (lr) : 0x00000000
            DSI Status (dsisr) : 0x01847318
            Data Address (dar) : 0x00000000
680x0 emulated registers:
DATA: 689B1CAE 00000003 00000000 00000000 00000000 00000000 00000000 00000000
ADDR: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 65AD70C0
FPU0:                0                0                0                0
FPU4:                0                0                0                0
Symbol info:
Instruction pointer 0x00000000 belongs to module "" (HUNK/Kickstart)
Stack trace:
    symbol not available
    native kernel module kernel+0x0003ca6c
PPC disassembly:
 fffffff8: XXXXXXXX   illegal address
 fffffffc: XXXXXXXX   illegal address
 00000000: XXXXXXXX   illegal address
 00000004: XXXXXXXX   illegal address
 00000008: XXXXXXXX   illegal address
System information:
CPU
 Model: Motorola MPC 7447/7457 Apollo V1.1
 CPU speed: 999 MHz
 FSB speed: 133 MHz
 Extensions: performancemonitor altivec
Machine
 Machine name: Pegasos II
 Memory: 1048576 KB
 Extensions: bus.pci bus.agp
Expansion buses
 PCI/AGP
  00:00.0 Vendor 0x11AB Device 0x6460
  00:01.0 Vendor 0x1106 Device 0x3044
   Range 0: 80002000 - 80002800 (MEM)
   Range 1: 00001080 - 00001100 (IO)
  00:05.0 Vendor 0x1033 Device 0x0035
   Range 0: 80000000 - 80001000 (MEM)
  00:05.1 Vendor 0x1033 Device 0x0035
   Range 0: 80001000 - 80002000 (MEM)
  00:05.2 Vendor 0x1033 Device 0x00E0
   Range 0: 80002800 - 80002900 (MEM)
  00:06.0 Vendor 0x1095 Device 0x3114
   Range 0: 00001030 - 00001038 (IO)
   Range 1: 00001038 - 0000103C (IO)
   Range 2: 00001100 - 00001108 (IO)
   Range 3: 00001038 - 0000103C (IO)
   Range 4: 00001110 - 00001120 (IO)
  00:0C.0 Vendor 0x1106 Device 0x8231
  00:0C.1 Vendor 0x1106 Device 0x0571
   Range 0: 00001000 - 00001008 (IO)
   Range 1: 00001008 - 0000100C (IO)
   Range 2: 00001010 - 00001018 (IO)
   Range 3: 00001018 - 0000101C (IO)
   Range 4: 00001020 - 00001030 (IO)
  00:0C.2 Vendor 0x1106 Device 0x3038
   Range 4: 00001040 - 00001060 (IO)
  00:0C.3 Vendor 0x1106 Device 0x3038
   Range 4: 00001060 - 00001080 (IO)
  00:0C.4 Vendor 0x1106 Device 0x8235
  00:0C.5 Vendor 0x1106 Device 0x3058
   Range 0: 00001200 - 00001300 (IO)
   Range 1: 00001108 - 0000110C (IO)
   Range 2: 00001108 - 0000110C (IO)
  00:0C.6 Vendor 0x1106 Device 0x3068
   Range 0: 00001300 - 00001400 (IO)
  00:0D.0 Vendor 0x1106 Device 0x3065
   Range 0: 00001400 - 00001500 (IO)
   Range 1: 80002900 - 80002A00 (MEM)
  01:00.0 Vendor 0x11AB Device 0x6460
  01:08.0 Vendor 0x1002 Device 0x5960
   Range 0: C0000000 - D0000000 (PREF.MEM)
   Range 1: 00001000 - 00001100 (IO)
   Range 2: D0000000 - D0010000 (MEM)
Libraries
 0x68f16958: english-british.language V52.1
 0x021b69a6: exec.library V53.58
 0x6ff7f714: vilintuisup.library V0.9
 0x6ff7f5e8: cgxvideo.library V42.1
 0x6ff620e0: cybergraphics.library V43.0
 0x6570cf20: getscreenmode.gadget V53.8
 0x6581b4a8: minigl.library V2.5
 0x686f46f0: Warp3D.library V53.18
 0x62211be8: W3D_Avenger.library V53.1
 0x62211ee8: W3D_Napalm.library V53.1
 0x57b08b98: W3D_Permedia2.library V52.42
 0x57b08c98: W3D_R200.library V53.21
 0x6570ce78: W3D_Picasso96.library V53.10
 0x620d6dc8: speedbar.gadget V53.12
 0x60d7a860: texteditor.gadget V53.20
 0x6570cd40: Popmenu.mui V20.226
 0x66159a38: bz2.library V53.3
 0x6570cc00: Pixmap.mui V20.57
 0x6570c160: Lamp.mcc V20.69
 0x689513f0: Gauge.mui V20.279
 0x66215eb0: Dtpic.mui V20.296
 0x66215cd0: Popasl.mui V20.265
 0x66215b90: String.mui V20.110
 0x66215af0: Listtree.mcc V20.146
 0x66215a50: Title.mui V20.89
 0x6621016c: codesets.library V6.16
 0x661f89c0: muimaster.library V20.6092
 0x68991ed4: asyncio.library V50.3
 0x66211d98: pthreads.library V53.9
 0x66211518: Separator.docky V53.2
 0x67733b24: device.audio V6.2
 0x66a83d60: slider.gadget V53.13
 0x66c052e4: filesave.audio V6.3
 0x66a83180: getfont.gadget V53.9
 0x66a83040: getfile.gadget V53.11
 0x66d63648: clicktab.gadget V53.39
 0x68951e90: arexx.class V53.3
 0x68951cb0: checkbox.gadget V53.9
 0x66aee760: requester.class V53.18
 0x68951f30: space.gadget V53.6
 0x66c051a8: chooser.gadget V53.18
 0x68951b70: penmap.image V53.5
 0x68951ad0: bitmap.image V53.9
 0x68951a30: integer.gadget V53.10
 0x66a09a98: screenblanker.library V53.6
 0x66acd0d4: asl.library V53.49
 0x6871f858: via-ac97.audio V5.9
 0x6ff91938: listbrowser.gadget V53.61
 0x66a08020: string.gadget V53.16
 0x68951490: scroller.gadget V53.13
 0x68eb65d4: usergroup.library V4.30
 0x68817ab8: emulation.library V53.3
 0x688c9a60: bsdsocket.library V4.307
 0x68f03720: mathieeedoubbas.library V52.1
 0x6fd486cc: textclip.library V52.2
 0x68f215b8: usbhidgate.library V52.2
 0x68eb0a5c: xadmaster.library V13.1
 0x68d0bd44: xpkmaster.library V5.2
 0x68d0b03c: hid.usbfd V53.8
 0x68f07ea0: button.gadget V53.15
 0x68f07f40: glyph.image V53.3
 0x68d2f530: window.class V53.50
 0x68cd7518: popupmenu.class V53.2
 0x68d85098: popupmenu.library V53.11
 0x68f07e00: label.image V53.12
 0x6ff7f7c8: layout.gadget V53.19
 0x68cd7420: bevel.image V53.6
 0x68f07d60: drawlist.image V53.3
 0x68f07900: png.datatype V53.6
 0x68d315c4: picture.datatype V53.6
 0x68eab07c: ft2.library V53.1
 0x6ff00c4c: workbench.library V53.51
 0x68fac9d8: timezone.library V53.8
 0x68fbac58: application.library V53.12
 0x6fffb6ac: commodities.library V53.7
 0x68f9f140: datatypes.library V53.4
 0x68f5f370: Picasso96API.library V53.4
 0x68f5db70: gadtools.library V53.6
 0x6909f8cc: icon.library V53.13
 0x6946a7c8: version.library V53.11
 0x68f5d450: iffparse.library V53.1
 0x6fcda7cc: locale.library V53.6
 0x6ff5c7ac: diskfont.library V53.4
 0x6fc8e6e8: petunia.library V53.4
 0x6fc8e568: diskcache.library V3.30
 0x6fc46690: dos.library V53.145
 0x6ff7fad4: usbprivate.library V53.12
 0x6ff3643c: massstorage.usbfd V53.13
 0x6ff363a8: bootkeyboard.usbfd V52.3
 0x6ff36328: bootmouse.usbfd V53.1
 0x6ff7f98c: hub.usbfd V53.8
 0x6ff7f8dc: usbresource.library V53.12
 0x6ff5b478: hunk.library V53.4
 0x6ffa4414: elf.library V53.19
 0x6ff894d0: intuition.library V53.43
 0x6ff3f150: rtg.library V53.30
 0x6ff928a0: ATIRadeon.chip V53.26
 0x6ff92824: PCIGraphics.card V53.5
 0x6ffa6a10: keymap.library V53.3
 0x6ff81340: layers.library V53.7
 0x6ffb4420: graphics.library V53.6
 0x6ff5b044: nonvolatile.library V53.5
 0x6ffa7438: newlib.library V53.28
 0x6ff901ac: utility.library V53.5
 0x6ffa60a8: expansion.library V53.1
 0x689b1cae: rexxsyslib.library V53.4 (Legacy)
Devices
 0x6895b614: clipboard.device V53.2
 0x66ad06e8: via-rhine.device V53.4
 0x67fc3854: ahi.device V6.6
 0x68f216e4: diskimage.device V52.78
 0x6ff90b10: usbsys.device V53.12
 0x6ff5baf0: ehci.usbhcd V53.17
 0x6ff5ba50: ohci.usbhcd V53.19
 0x6ff5b9b0: uhci.usbhcd V53.12
 0x6ff5b844: sii3114ide.device V53.15
 0x6ff92c24: peg2ide.device V53.15
 0x6fffb338: console.device V53.1
 0x6ff913f0: ramdrive.device V52.6
 0x6ffa6c5c: input.device V53.4
 0x6ff5c3b4: keyboard.device V53.10
 0x6ff912d0: timer.device V53.1
Tasks
 DepthToFront (Waiting)
  Stack: 0x66ad5004 - 0x66ae4ffc, pointer @ 0x66ae49e0 (Cookie OK)
  State: Process (Waiting)
 ClickToFront (Waiting)
  Stack: 0x66be2004 - 0x66bf1ffc, pointer @ 0x66bf19f0 (Cookie OK)
 input.device (Waiting)
  Stack: 0x6ff47000 - 0x6ff57000, pointer @ 0x6ff56f00 (Cookie OK)
  State: Task (Waiting)
 SFS DosList handler (Waiting)
  Stack: 0x6fbad004 - 0x6fbafffc, pointer @ 0x6fbaff20 (Cookie OK)
 USB stack (Waiting)
  Stack: 0x6febb000 - 0x6febf000, pointer @ 0x6febef20 (Cookie OK)
 EHCI Controller Task Unit 0 (Waiting)
  Stack: 0x6fd26000 - 0x6fd2e000, pointer @ 0x6fd2df20 (Cookie OK)
  Signals: SigRec 0xbe009000, SigWait 0x00000000
 UHCI Controller Task Unit 1 (Waiting)
  Stack: 0x6fdb6000 - 0x6fdbe000, pointer @ 0x6fdbdf20 (Cookie OK)
  Signals: SigRec 0xbe001000, SigWait 0x00000000
 UHCI Controller Task Unit 0 (Waiting)
  Stack: 0x6fdf6000 - 0x6fdfe000, pointer @ 0x6fdfdf20 (Cookie OK)
 OHCI Controller Task Unit 0 (Waiting)
  Stack: 0x6fd6a000 - 0x6fd72000, pointer @ 0x6fd71f20 (Cookie OK)
  Signals: SigRec 0xbc009000, SigWait 0x00000000
 OHCI Controller Task Unit 1 (Waiting)
  Stack: 0x6fd4a000 - 0x6fd52000, pointer @ 0x6fd51f20 (Cookie OK)
 sii3114ide.device - chip 0 port 0 (Waiting)
  Stack: 0x6fe5e000 - 0x6fe66000, pointer @ 0x6fe65f30 (Cookie OK)
 page_sweep (Waiting)
  Stack: 0x6fe06004 - 0x6fe0dffc, pointer @ 0x6fe0de70 (Cookie OK)
 via-rhine.device [0 (Waiting)
  Stack: 0x66e12004 - 0x66e21ffc, pointer @ 0x66e21f10 (Cookie OK)
  Signals: SigRec 0xf0008000, SigWait 0x00000000
 peg2ide.device - chip 0 port 1 (Waiting)
  Stack: 0x6fe76000 - 0x6fe7e000, pointer @ 0x6fe7df30 (Cookie OK)
 sii3114ide.device - chip 0 port 1 (Waiting)
  Stack: 0x6fe36000 - 0x6fe3e000, pointer @ 0x6fe3df30 (Cookie OK)
 peg2ide.device - chip 0 port 0 (Waiting)
  Stack: 0x6fe96000 - 0x6fe9e000, pointer @ 0x6fe9df30 (Cookie OK)
 hid.usbfd (Waiting)
  Stack: 0x6fc3a004 - 0x6fc41ffc, pointer @ 0x6fc41e90 (Cookie OK)
  Signals: SigRec 0xe0000000, SigWait 0x00000100
 HID Mouse (Waiting)
  Stack: 0x68996004 - 0x689a5ffc, pointer @ 0x689a5f20 (Cookie OK)
 JXF:hd3/JXFileSystem 4.34  (Waiting)
  Stack: 0x694e7004 - 0x694e9ffc, pointer @ 0x694e9de0 (Cookie OK)
  Signals: SigRec 0xc0000100, SigWait 0x20000000
 JXF:hd6/JXFileSystem 4.34  (Waiting)
  Stack: 0x694ee004 - 0x694f0ffc, pointer @ 0x694f0de0 (Cookie OK)
 ICD0/CDFileSystem 53.4  (Waiting)
  Stack: 0x68926004 - 0x68935ffc, pointer @ 0x68935f30 (Cookie OK)
 RAM/ram-handler 53.3  (Waiting)
  Stack: 0x69326004 - 0x6932dffc, pointer @ 0x6932dc90 (Cookie OK)
 JXF:hd9/JXFileSystem 4.34  (Waiting)
  Stack: 0x694e0004 - 0x694e2ffc, pointer @ 0x694e2de0 (Cookie OK)
 JXF:hd8/JXFileSystem 4.34  (Waiting)
  Stack: 0x6fbbb004 - 0x6fbbdffc, pointer @ 0x6fbbdde0 (Cookie OK)
  Stack: 0x6fbb4004 - 0x6fbb6ffc, pointer @ 0x6fbb6f30 (Cookie OK)
 hd0/SmartFilesystem 1.290  (Waiting)
  Stack: 0x6fba6004 - 0x6fba8ffc, pointer @ 0x6fba8eb0 (Cookie OK)
 reaper.task (Waiting)
  Stack: 0x690ce004 - 0x690d5ffc, pointer @ 0x690d5760 (Cookie OK)
 dos_filedir_notify (Waiting)
  Stack: 0x6fbea004 - 0x6fbedffc, pointer @ 0x6fbedad0 (Cookie OK)
  Signals: SigRec 0x40001000, SigWait 0x80000000
 hid.usbfd (Waiting)
  Stack: 0x6fc6e004 - 0x6fc75ffc, pointer @ 0x6fc75e90 (Cookie OK)
 HID Keyboard (Waiting)
  Stack: 0x688aa004 - 0x688b9ffc, pointer @ 0x688b9f00 (Cookie OK)
  Signals: SigRec 0x90001000, SigWait 0x00000000
 hid.usbfd (Waiting)
  Stack: 0x68a4f004 - 0x68a56ffc, pointer @ 0x68a56e90 (Cookie OK)
 HID Consumer (Waiting)
  Stack: 0x68976004 - 0x68985ffc, pointer @ 0x68985f20 (Cookie OK)
 pager (Waiting)
  Stack: 0x690aa004 - 0x690c9ffc, pointer @ 0x690c9f00 (Cookie OK)
 IDF0/FastFileSystem 53.2  (Waiting)
  Stack: 0x68a5b004 - 0x68a6affc, pointer @ 0x68a6aed0 (Cookie OK)
  Signals: SigRec 0xa8000100, SigWait 0x00000000
 ENV/env-handler 52.2  (Waiting)
  Stack: 0x68fd0004 - 0x68fd2ffc, pointer @ 0x68fd2e00 (Cookie OK)
 CON/con-handler 53.1  (Waiting)
  Stack: 0x65e3e004 - 0x65e4dffc, pointer @ 0x65e4dde0 (Cookie OK)
 URL/launch-handler 53.32  (Waiting)
  Stack: 0x68827004 - 0x688a1ffc, pointer @ 0x6889cac0 (Cookie OK)
 RANDOM/Random-Handler 52.1  (Waiting)
  Stack: 0x68a8c004 - 0x68a9bffc, pointer @ 0x68a9bef0 (Cookie OK)
  Stack: 0x4ed1b004 - 0x4ed2affc, pointer @ 0x4ed2ade0 (Cookie OK)
 console.device (Waiting)
  Stack: 0x6fef7000 - 0x6feff000, pointer @ 0x6fefef70 (Cookie OK)
  Signals: SigRec 0xf0000000, SigWait 0x00000000
  Stack: 0x66b25004 - 0x66b34ffc, pointer @ 0x66b34de0 (Cookie OK)
  Stack: 0x66baa004 - 0x66bb9ffc, pointer @ 0x66bb9de0 (Cookie OK)
  Stack: 0x66c27004 - 0x66c36ffc, pointer @ 0x66c36de0 (Cookie OK)
  Stack: 0x66c95004 - 0x66ca4ffc, pointer @ 0x66ca4de0 (Cookie OK)
  Stack: 0x66d1b004 - 0x66d2affc, pointer @ 0x66d2ade0 (Cookie OK)
 AUDIO/AHI-Handler 6.2  (Waiting)
  Stack: 0x687e8004 - 0x687f7ffc, pointer @ 0x687f7ec0 (Cookie OK)
 APPDIR/appdir-handler-dos 53.145  (Waiting)
  Stack: 0x694f5004 - 0x694f7ffc, pointer @ 0x694f7da0 (Cookie OK)
  Stack: 0x692da004 - 0x692e1ffc, pointer @ 0x692e1de0 (Cookie OK)
 RAW/con-handler 53.1  (Waiting)
  Stack: 0x69352004 - 0x69359ffc, pointer @ 0x69359de0 (Cookie OK)
  Stack: 0x6935e004 - 0x69365ffc, pointer @ 0x69365de0 (Cookie OK)
 dos_nbmd_process (Waiting)
  Stack: 0x6fbf9004 - 0x6fbfbffc, pointer @ 0x6fbfbf30 (Cookie OK)
 dos_lock_handler (Waiting)
  Stack: 0x6fbf2004 - 0x6fbf4ffc, pointer @ 0x6fbf4ef0 (Cookie OK)
 RexxMaster (Waiting)
  Stack: 0x6875e004 - 0x6876dffc, pointer @ 0x6876df50 (Cookie OK)
  Stack: 0x688f7004 - 0x6890affc, pointer @ 0x6890ac20 (Cookie OK)
  Stack: 0x6893a004 - 0x6894dffc, pointer @ 0x6894dc20 (Cookie OK)
 TEXTCLIP/textclip-handler 52.2  (Waiting)
  Stack: 0x68807004 - 0x68816ffc, pointer @ 0x68816eb0 (Cookie OK)
 compose.task (Waiting)
  Stack: 0x654db000 - 0x654e3000, pointer @ 0x654e2f30 (Cookie OK)
  Signals: SigRec 0x00000021, SigWait 0x00000000
  Stack: 0x6777b000 - 0x67783000, pointer @ 0x67782f30 (Cookie OK)
 ScreenBlanker Library. (Waiting)
  Stack: 0x66a94004 - 0x66aa4ffc, pointer @ 0x66aa4f00 (Cookie OK)
  Signals: SigRec 0xb4001000, SigWait 0x00000100
 Workbench (Waiting)
  Stack: 0x686d4004 - 0x686e3ffc, pointer @ 0x686e3ea0 (Cookie OK)
  Stack: 0x669c6004 - 0x669d5ffc, pointer @ 0x669d5f40 (Cookie OK)
 ramlib (Waiting)
  Stack: 0x69018004 - 0x69030ffc, pointer @ 0x69030f20 (Cookie OK)
 texteditor.gadget Clipboard Server (Waiting)
  Stack: 0x66de1004 - 0x66df9ffc, pointer @ 0x66df9f00 (Cookie OK)
 MUI imagespace screen notify (Waiting)
  Stack: 0x65895004 - 0x658a4ffc, pointer @ 0x658a4d00 (Cookie OK)
 ContextMenus Command Dispatcher (Waiting)
  Stack: 0x66e5e004 - 0x66e6dffc, pointer @ 0x66e6df40 (Cookie OK)
  Stack: 0x66f20004 - 0x66f2fffc, pointer @ 0x66f2fdb0 (Cookie OK)
  Stack: 0x66f7d004 - 0x66f8cffc, pointer @ 0x66f8cf00 (Cookie OK)
 RinghioServer (Waiting)
  Stack: 0x66b39004 - 0x66b58ffc, pointer @ 0x66b583a0 (Cookie OK)
  Signals: SigRec 0xd8001000, SigWait 0x00000100
 AmiDock (Waiting)
  Stack: 0x66d2f004 - 0x66d3effc, pointer @ 0x66d3e910 (Cookie OK)
  Signals: SigRec 0x00000100, SigWait 0x00080000
 TCP/IP Control (Waiting)
  Stack: 0x6698e004 - 0x6699dffc, pointer @ 0x6699ddc0 (Cookie OK)
  Signals: SigRec 0xf8009080, SigWait 0x00000000
 hub.usbfd (Waiting)
  Stack: 0x6fcba004 - 0x6fcc1ffc, pointer @ 0x6fcc1f00 (Cookie OK)
 hub.usbfd (Waiting)
  Stack: 0x6fc96004 - 0x6fc9dffc, pointer @ 0x6fc9df00 (Cookie OK)
 hub.usbfd (Waiting)
  Stack: 0x6fcc6004 - 0x6fccdffc, pointer @ 0x6fccdf00 (Cookie OK)
 Docket (Waiting)
  Stack: 0x4c8e7004 - 0x4c8f6ffc, pointer @ 0x4c8f6c60 (Cookie OK)
  Signals: SigRec 0xe0001000, SigWait 0x00000100
 [OWB] JavaScriptCore::BlockFree (Waiting)
  Stack: 0x620fc004 - 0x6217bffc, pointer @ 0x6217be50 (Cookie OK)
 [OWB] Timer (Waiting)
  Stack: 0x65580004 - 0x6558fffc, pointer @ 0x6558fed0 (Cookie OK)
  Signals: SigRec 0x50000000, SigWait 0x00000000
 ContextMenus (Waiting)
  Stack: 0x66bc6004 - 0x66bd5ffc, pointer @ 0x66bd5c50 (Cookie OK)
  Signals: SigRec 0xe0001000, SigWait 0x04000000
 TCP/IP Superserver (Waiting)
  Stack: 0x669aa004 - 0x669b9ffc, pointer @ 0x669b99f0 (Cookie OK)
  Signals: SigRec 0xd0000080, SigWait 0x00000000
 [OWB] IconDatabase (Waiting)
  Stack: 0x65731004 - 0x657b0ffc, pointer @ 0x657b0ea0 (Cookie OK)
  Signals: SigRec 0x00000010, SigWait 0x00000000
  Stack: 0x67641004 - 0x67650ffc, pointer @ 0x67650e10 (Cookie OK)
  Signals: SigRec 0xf8003000, SigWait 0x00000000
 FKey (Waiting)
  Stack: 0x66af9004 - 0x66b08ffc, pointer @ 0x66b08d20 (Cookie OK)
  Signals: SigRec 0xc000d000, SigWait 0x00000000
 « IPrefs » (Waiting)
  Stack: 0x68ebc004 - 0x68ecbffc, pointer @ 0x68ecb980 (Cookie OK)
  Signals: SigRec 0x0000f000, SigWait 0x20000100
 ScreenBlankerEngine (Waiting)
  Stack: 0x66c3b004 - 0x66c4affc, pointer @ 0x66c4ab10 (Cookie OK)
  Signals: SigRec 0xb8001000, SigWait 0x00000000
 MUI-PubScreen-0000000b (Waiting)
  Stack: 0x6550b004 - 0x6551affc, pointer @ 0x6551ac10 (Cookie OK)
 ASYNCWB (Waiting)
  Stack: 0x66cd6004 - 0x66ce5ffc, pointer @ 0x66ce5e80 (Cookie OK)
  Stack: 0x68ea8000 - 0x68ea8fa0, pointer @ 0x68ea8f10 (Cookie OK)
 DefIcons (Waiting)
  Stack: 0x66ca9004 - 0x66cb8ffc, pointer @ 0x66cb8dc0 (Cookie OK)
 RAWBInfo (Waiting)
  Stack: 0x66c4f004 - 0x66c5effc, pointer @ 0x66c5eec0 (Cookie OK)
 TCP/IP Log (Waiting)
  Stack: 0x68f7e004 - 0x68f8dffc, pointer @ 0x68f8df00 (Cookie OK)
 ConClip (Waiting)
  Stack: 0x687ac004 - 0x687bbffc, pointer @ 0x687bbeb0 (Cookie OK)
 USB stack Process (Waiting)
  Stack: 0x68acd004 - 0x68adcffc, pointer @ 0x68adcee0 (Cookie OK)
 datatypes.library (Waiting)
  Stack: 0x68cab004 - 0x68cbaffc, pointer @ 0x68cbaf10 (Cookie OK)
 DST watcher (Waiting)
  Stack: 0x68e78004 - 0x68e87ffc, pointer @ 0x68e87f10 (Cookie OK)
 SMI Handler Process (Waiting)
  Stack: 0x68ff8004 - 0x69007ffc, pointer @ 0x69007f40 (Cookie OK)
  Signals: SigRec 0x00001000, SigWait 0x00000000
 hub.usbfd (Waiting)
  Stack: 0x6fcae004 - 0x6fcb5ffc, pointer @ 0x6fcb5f00 (Cookie OK)
 hub.usbfd (Waiting)
  Stack: 0x6fca2004 - 0x6fca9ffc, pointer @ 0x6fca9f00 (Cookie OK)
 OWB (Crashed)
  Stack: 0x658ef004 - 0x65ad7ffc, pointer @ 0x020991e0 (Cookie OK)
  Signals: SigRec 0x07c0d000, SigWait 0x06004180
  State: Process (Crashed)
 ramlib.support (Waiting)
  Stack: 0x69035004 - 0x6904dffc, pointer @ 0x6904df00 (Cookie OK)
  Signals: SigRec 0x80005000, SigWait 0x00000000
 dos_signal_server (Waiting)
  Stack: 0x6fc00004 - 0x6fc02ffc, pointer @ 0x6fc02f10 (Cookie OK)
  Signals: SigRec 0x0000f000, SigWait 0x00000000
 Picasso96 (Waiting)
  Stack: 0x68ef0004 - 0x68effffc, pointer @ 0x68effd70 (Cookie OK)
 dos_appdir_server (Waiting)
  Stack: 0x6fc07004 - 0x6fc09ffc, pointer @ 0x6fc09d40 (Cookie OK)
 idle.task (Ready)
  Stack: 0x6ff82000 - 0x6ff83000, pointer @ 0x6ff82fd0 (Cookie OK)
  State: Task (Ready)
mlehto wrote:I played around internet with OWB. Crashlog says OWB. Intresting part was, that stack was outside bounds.
Raise the stack in OWB's icon.
salass00
Post by salass00 »
OWB (Crashed)
Either OWB uses ridiculous amounts of stack or something has trashed it's stack pointer.
Taking "0x65ad7ffc - 0x020991e0" that's about 1.5GB stack used :shock:.
mlehto
Post by mlehto »
@salass
Heh, it was default 32768. Now 128000.
I have only 1 gig mem.
Still, should kernel and kernel modules be in proteted memory ?
Symbol info:
Wich one crashed ? OWB first and writed over protected memory or kernel?
salass00
Post by salass00 »
@mlehto
Looking at the stack bounds OWB has 2002936 bytes of stack that it can use (that's about 1.9 MB) so it probably has a stack cookie inside the executable that's overriding the number set on the icon.
Since the stack pointer is so out of bounds you can probably not trust the stack trace. Address 0x00000000 is definitely not an executable region which is why it caused an ISI.
