Directing returned code to NIL (SOLVED)
AmigaPhil
Post by AmigaPhil »
Sorry if this has already been signaled.
One of my DOS scripts opens a shell window showing the return code, but it should not (it doesn't on OS3).
The command doing this is:
rx >NIL: SpamFryer.rexx
Same problem after extracting archive using the contextual menu : a shell window opens with return code 10.
In ExtractArc.rexx :
'xadunfile >NIL: 'file' DEST='path
The NIL: device is not behaving like in OS3 ?
Edit : (About ExtractArc.rexx)
The "Command returned 10" is caused by this line:
window windows path open
I don't know what it is supposed to do, but there is no "window" command.
which window
(no such command in the path)
My question about NIL: remain :
- on OS3, the return code is not shown.
- on OS4, the return code (5) is shown. Why ?
Note: SpamFryer returns code 5 if, for example, there is no waiting mail in the queried POP server. This is intended.
However, there is no point showing this code when run from workbench (iconx icon). It can confuse the user and let him think that something went wrong with the script.
gazelle
Re: Directing returned code to NIL
Post by gazelle »
In AmigaOS 4 the error output must be redirected seperatly with "*>"
rx >NIL: *>NIL: SpamFryer.rexx
should work
AmigaPhil
Post by AmigaPhil »
gazelle wrote:In AmigaOS 4 the error output must be redirected seperatly with "*>"
should work
Yes, it works. Thanks ! :)
Any incidences if I add this "*>NIL:" under OS2/OS3 ?
