failure of update 5 SOLVED
- Paul Zager
I ran the update on my A1-XE. Reboot started. It got part way through then said it couldn't find 3dfxVoodo.chip and quit booting. Short of taking things apart and using my backup HD as the main HD, it looks like I'm in serious trouble.
A1-XE G4, 2GB, 9250
X5000/20
A1-XE G4, 2GB, 9250
X5000/20
Re: failure of update 5
Lets get the obvious out of the way
You did install Update5 over a fresh installation of AmigaOS 4.1.4?
Did you notice anything strange or get any feedback that "something" had occured during the installation process?
Try booting up with your AmigaOS CDRom right up into the workbench option. Fire up DirOpus and get a listing of your Harddrive kickstart directory then locate the 3dfxVoodo.chip file on the CDRom and copy it over.
Another way would be to edit kicklayout in kickstart directory and put a ; infront of
MODULE Kickstart/3dfxVoodoo.chip
It seems a little strange what has happened here, either you've edited something which has carried on through or the update process hasn't detected something
See how you go anyway
I don't remember enough about the generic installation on the A1-XE even though I own one of these machines (been dead and in a box for many years now)
@Slayer:
@Paul:
Do what Slayer's ghost suggested. I notice that the error message says "3dfxVoodo.chip". Is that really what it says? It is miss-spelled, it should be "3dfxVoodoo.chip". I wonder if you have a corrupted Kicklayout file?
Sorry to hear it. Who was that usurper I met a few months back using your name?...I own one of these machines (been dead and in a box for many years now).
@Paul:
I have been meaning to get it going but when it last packed a sad it was exactly the same time I got my first SAM and of course the rest is history. Perhaps once I've got my A4000 PPC back in action I'll take a look at the MB in the box
Thanks for the encouragement
- Paul Zager
The misspelling is my fault. I think I caught it and corrected it on the amigans.net post.Do what Slayer's ghost suggested. I notice that the error message says "3dfxVoodo.chip". Is that really what it says? It is miss-spelled, it should be "3dfxVoodoo.chip". I wonder if you have a corrupted Kicklayout file?
As noted over on Amigans, booting from my 4.1 CD results in a black screen so I can't do any editing. I've switched over from my HDMI cable to a VGA and I'm still getting a black screen. So I'm kind of stuck for now.
A1-XE G4, 2GB, 9250
X5000/20
A1-XE G4, 2GB, 9250
X5000/20
- Paul Zager
Re: failure of update 5 SOLVED
Problem solved. I had to take out my USB2 card first 'cause I was trying to boot from the original 4.1 before there was USB2 support.. Still got the black screen. So I reset the UBOOT to factory defaults and finally was able to boot into 4.1.0 from the original CD. So I was finally able to edit the update 5 Kicklayout now, and I'm replying from my update 5 setup. Thanks for paying attention to my questions.
Paul
Paul
A1-XE G4, 2GB, 9250
X5000/20
A1-XE G4, 2GB, 9250
X5000/20
