Is there some configuration that i am missing?sys:rexxc/rxset: Comando sconosciuto
9 *-* 'sys:rexxc/rxset' id '`requestfile DRAWERSONLY TITLE="...
+++ Command returned 10
manca un argomento dopo la parola chiave
14 *-* 'xadunfile 'file' DEST='path;
+++ Command returned 20
Context Menu "Extract" and archive file
- nubechecorre
When i try to open an archive like lha or zip using the context menu option "extract" i get this message:
http://www.os4games.it
Sam440ep mini-itx
Classic System:
Amiga 1200
Radeon 9250 128Mb VRam
Voodoo 3 3000 16Mb VRam
DVD-RW LG Dual Layer
SoundBlaster PCI 128
Cocolino Interface Elbox
AmigaOne White Mouse
Sam440ep mini-itx
Classic System:
Amiga 1200
Re: Context Menu "Extract" and archive file
What's the version of the file ExtractArc.rexx in your Sys:S/Arexx/ drawer? And the rx one too?
Regards,
Petrol.
Regards,
Petrol.
I got the same problem here, but:
Is that the correct default path under a standard AmigaOS4 installation ?sys:rexxc/rxset
HEre Rxset is in root of the C: drawer.
Regards,
Petrol.
Regards,
Petrol.
Same here so "rexxc" part on the current default path may be wrong, can it be an old AmigaOS3 path
Could you give the version of the file ExtractArc.rexx in your Sys:S/Arexx/ drawer?
Regards,
Petrol.
Regards,
Petrol.
Sure it is:
EDIT: I solve the problem !
On ExtractArc.rexx file I just modify this line:
I use AmigaOS 4.1 Update 4 of courseExtractArc.rexx 52.2 (17.12.2006) Christoph Gutjahr
To:'sys:rexxc/rxset' id '`requestfile DRAWERSONLY TITLE="Select destination directory"`'
So in short as i suspected the "rexxc" path is wrong and need to be changed to "c", please can you add a ticket for that ?'sys:c/rxset' id '`requestfile DRAWERSONLY TITLE="Select destination directory"`'
It ought to be c:rxsetsamo79 wrote:To:'sys:rexxc/rxset' id '`requestfile DRAWERSONLY TITLE="Select destination directory"`'
In fact, it should always have been that
- nubechecorre
Thanks Chris, thanks Samo
I wonder why no one complains about that problem...
Sam440ep mini-itx
Classic System:
Amiga 1200
Sam440ep mini-itx
Classic System:
Amiga 1200
Yep infact is a bit strange, this ARexx file is quite old (2006, from the OS 4.0 era ?), maybe at the time the path was different and correct under OS 4.0 but since then maybe they forget to update it according to the new (?) path on 4.1 or just they decide to not release an update for it (yet).
Don't know i never use AmigaOS 4.0 at home, my first AmigaOS was the 4.1
