Hello,
I just loaded some prefs from my old SAM440 OS4.1 (here:Screen.prefs) into my new X1000 OS4.1upd5 installation. After saving "Screen Prefs" I am getting a message "Need Volume WB4:"....
Seems logical as I my System Partition was called "WB4" on my old SAM. Seems there are some WB4: left instead of SYS:. However, I tried to change every path inside "Screens Prefs" to "SYS:....", but I still get the above message. Where else can/do I have to change the path ? Of course I could overcome by "Assign WB4: ...." in User-Startup, but I'd rather do it properly !
Thanx for hints
Edit: SOLVED !!!
[SOLVED] IPrefs looking for non existant Volume/Assign..
Re: IPrefs looking for non existant Volume/Assign..
Open "Find" (WB-pull-down menu/Window/Last Entry)gerograph wrote:Hello,
Thanx for hints
Click "None"
Click "Add path"
CD to "Envarc:Sys" and click OK
Type "WB4:" into the "Contents" field and "Start"
Most of the .prefs files are either XML nowadays or iff form (whatever that means)
Find will give you all files with the string inside (readable) and you can start altering them with the corresponding preferences program
You "could" also change the path by hand with Notepad, but i'd refrain from that because it might make the .prefs file unreadable
People are dying.
How dare you!
– Greta Thunberg
How dare you!
– Greta Thunberg
- MichaelMerkel
check the gui prefs inside screens prefs.gerograph wrote:Hello,
Thanx for hints
anyway - the SYStem partition should be accessed with SYS: and not with the label or partition name. this makes life easier.
regards...
michael
In my experience, likely places are wbpattern.prefs and the AmiDock XML configuration file. Maybe (references to) WBPattern settings can be part of the screens.prefs? Not sure.gerograph wrote:Seems there are some WB4: left instead of SYS:. However, I tried to change every path inside "Screens Prefs" to "SYS:....", but I still get the above message. Where else can/do I have to change the path ?
But like Raziel suggests, using Find should help.
Yeah, AmiDock is annoying. When you drag something into it, it always stores the full path to the destination, including the volume name.
Whenever you drag something from the system disk (like a Commodity or docky) into AmiDock, you have to go in and edit the path from the volume name to SYS:.
This sounds like it would make a good bug/enhancement report to metonyw wrote:Yeah, AmiDock is annoying. When you drag something into it, it always stores the full path to the destination, including the volume name.
People are dying.
How dare you!
– Greta Thunberg
How dare you!
– Greta Thunberg
- colinw
Raziel wrote:This sounds like it would make a good bug/enhancement report to metonyw wrote:Yeah, AmiDock is annoying. When you drag something into it, it always stores the full path to the destination, including the volume name.
This is a good option to add to the function that builds the full paths, i'll consider a new flag for this feature.
Thanks.
Please consider it carefully since SYS: is an assignment that can be changed by the user. Would you want to use SYS: to build the full path if it doesn't point to the boot partition?colinw wrote: This is a good option to add to the function that builds the full paths, i'll consider a new flag for this feature.
Thanks.
Yes.xenic wrote:Please consider it carefully since SYS: is an assignment that can be changed by the user. Would you want to use SYS: to build the full path if it doesn't point to the boot partition?
The whole point of SYS: is to point to the root of the current boot partition. If anybody is mad enough to move the assignment "in mid-air" to something else, they are on their own for all other sorts of reasons. Weighed against all the (intended) benefits of being able to store paths in relation to whichever boot partition is the "live" one, I'd say sod 'em.
@nbache
agree... SYS: should always be your bootpartition.
@all
thanks for help, some of the screens had their own GUI Prefs... that's where it was hidden. However I might have mocked (spelling ??) something up or have a faulty preinstall - see my other threads. So I'll reinstall. Before I continue to costomize OS 4.1 on X1000. I'll put this one [SOLVED].
AmiDock wasn't transfered, yet. So this task/problem will occur later...
@all
