MintPPC
mintppc
MintPPC
Post by mintppc »
If there is interest, I am willing to create images of a working MintPPC installation partition. I don’t know if you run 32-bits or 64-bits. You would have to install the bootloader yourself as I don’t have access to your type of machines.
I can also experiment with qemu to make a complete image if I know how to do that. This is something I can experiment with later. Help with this will be appreciated.
Regards, Jeroen
Re: MintPPC
mintppc wrote: Tue May 06, 2025 6:27 am If there is interest, I am willing to create images of a working MintPPC installation partition. I don’t know if you run 32-bits or 64-bits. You would have to install the bootloader yourself as I don’t have access to your type of machines.
Thank you, Jeroen! But you seem to have forgotten that already a few years ago I created and published - with you permission - a working MintPPC system parttion image for AmigaOnes :-).
Please see this thread: viewtopic.php?t=4556
But it would be great if you could create a fresh, up-to-date system partition image! It has to to be 32-bit and work without Altivec. You kindly compiled a non-altivec version of VLC on my request (3.0.11.1).
PS. It might be good idea to continue this discussion on the earlier "MintPPC" thread, or at least slightly modify the subject line of this one.
