Freeze system with paste in gadget
turbo4.1
Post by turbo4.1 »
hello,
i found a strange behaviour on my system and i want to know is this a bug or only a failure on my system:
1) copy some text into the clipboard with amiga-c oder the copy-entry in a popup menu.
2) open a dialog in a program with a string-gadget. for example then notepad with openfile dialog.
3) paste the copied text into the string-gadget for the filename.
4) press the tab-key
an now my system is freezed!
has anyone the same problem?
system: sam440flex 667mhz, 1gb ram, radeon9250. aos4.1u4
greetings
achim
Amiga user since 1987
Sam440Flex 666Mhz, Radeon 9250, 1GB RAM
samo79
Re: Freeze system with paste in gadget
Post by samo79 »
Just tried and even following exactly your step i didn't have any freeze
Aniway did you look at ?
http://forum.hyperion-entertainment.biz ... f=14&t=625
A3000T
Post by A3000T »
I can't reproduce this freeze either.
Kind regards,
Dennis
turbo4.1
Post by turbo4.1 »
Thanks for verifying. I will test something other to found the problem.
ktadd
Post by ktadd »
This sound suspeciously like you might be running onto the same problem with Tab Cycling when using ActivateGadget (which I'm guessing the file requester does to activate the string gadget) that I just posted about here: http://forum.hyperion-entertainment.biz ... f=26&t=947
