Debian Squeeze Install Procedures Manual?
PatW
Re: Debian Squeeze Install Procedures Manual?
Post by PatW »
amigasociety wrote:
PatW wrote: 2) The reference to GNOME 3 should probably read GNOME 2 for the default Squeeze install.
Pat
Anyone know if Gnome 3 can be installed on this?
Or is that a Wheezy INstall only that can use Gnome 3?
tj
Hi TJ
Glad you got Debian up and running - I must check out your video :)
You would need to upgrade to Wheezy to get Gnome 3 (easily). There are no backports available and although it may be possible to build Gnome 3 from source for Squeeze you'd probably end up having to update an awful lot of Squeeze packages and be halfway to Wheezy by that point ;)
Pat
Fernecho
Post by Fernecho »
trevordick wrote:
Fernecho wrote:I have installed Debian Squeeze 6.0.4 Kernel "vmlinux39" in my AmigaONE X 1000.
The result was perfect, good job with the Installation Guide v1.8.3
thanks to all those who have enabled this project to the AmigaONE X1000.
Greetings
Excellent.
Did you have any difficulty or notice any errors/typos with the instructions?
Thansks
Trevor
Basically same thing that mentions PatW, and also this other command that is in the page 21:
setenv - p MENU_2_COMMAND "boot - elf - noints - fatfs CF0:vmlinux39NH", "CF0" should be "cf0".
But that's detectable easily and does not affect the installation, the installation guide is very easy to understand.
Amiga 1200 / Blizzard 1260 / Mediator 1200 / Voodoo 3000 / 64 Mb / AmigaOS 3.9
Sam Flex 440ep 733 Mhz / AmigaOS 4.1 u 4
AmigaONE X1000
trevordick
A-Eon Technology
A-Eon Technology
Post by trevordick »
Thanks Fernecho
Trevor
I'm just Breezin'
good manual. step by step. Everything is easy to understand.
Here is a screenshot of my debian
