I see on Hyperion's Blog that they have placed the Debian Squeeze kernel and X1000 installation guide in their download area for all registered owners of the X1000 to download and use.
Now I just need to find a link to that download area. I hope that my registration here in these support forums for X1000 owners will be recognized by this website and will allow me into the download area, so I can download the Debian Squeeze kernel and the X1000 installation guide.
Off to look for the download area for Hyperion and hoping that it will automatically recognize my login and allow me to get those downloads today.
Debian Squeeze Install Procedures Manual?
Re: Debian Squeeze Install Procedures Manual?
Efika 5200b w/MorphOS3.7
I think you've probably already discovered that the two sites are independent and you have registered there and typed in the serial for AmigaOS4.1.5 for the X1000 so you can access the Linux download area.
Yep! I had already registered on both sites, so it was no problem downloading the two files for the guide and the kernel. Now I am just waiting for the long download of the Debian 6.04 install DVD to finish, so I should have everything I need to do the install on my X1000 and try it out.Slayer wrote:I think you've probably already discovered that the two sites are independent and you have registered there and typed in the serial for AmigaOS4.1.5 for the X1000 so you can access the Linux download area.
Is the link broken or the site busy?
I have downloaded the kernel but I cannot download the installation guide.
Timberwolf, OWB and Firefox only find a 0 byte file, while NetSurf says "transfer closed with 3074933 bytes remaining to read"
A1000; A1200; A1500; Sam440ep 667MHz OS4.1; AmigaOne X1000
My mistake. File permissions were not set correctly. Fixed now.elginseam wrote:I have downloaded the kernel but I cannot download the installation guide.
There was a last minute update to the guide which is now at 1.8.3.
I have installed Debian Squeeze 6.0.4 Kernel "vmlinux39" in my AmigaONE X 1000.
The result was perfect, good job with the Installation Guide v1.8.3
thanks to all those who have enabled this project to the AmigaONE X1000.
Greetings
Greetings
Amiga 1200 / Blizzard 1260 / Mediator 1200 / Voodoo 3000 / 64 Mb / AmigaOS 3.9
Sam Flex 440ep 733 Mhz / AmigaOS 4.1 u 4
AmigaONE X1000
AmigaONE X1000
Neat, thanks for your hard work guys, I dont know if I will risk it, I'm pretty sure I can do it, but dont want to risk messing up my Amiga set up. Will re-read that manual a few times before I try any thing.
- trevordick
- A-Eon Technology
Excellent.Fernecho wrote:I have installed Debian Squeeze 6.0.4 Kernel "vmlinux39" in my AmigaONE X 1000.
Greetings
Did you have any difficulty or notice any errors/typos with the instructions?
Thansks
Trevor
I'm just Breezin'
Hi Trevortrevordick wrote: Did you have any difficulty or notice any errors/typos with the instructions?
Thansks
Trevor
Just two very minor points on page 20 of v1.8.3
1) cp -r /media/USB/2.6.39.4X1000 /lib/modules should read (lowercase 'usb')
cp -r /media/usb/2.6.39.4X1000 /lib/modules2) The reference to GNOME 3 should probably read GNOME 2 for the default Squeeze install.
The guide is really good, very clear and a lot of effort was obviously put in to creating it - really appreciate it
Thanks again
Pat
- amigasociety
PatW wrote: 2) The reference to GNOME 3 should probably read GNOME 2 for the default Squeeze install.
Pat
Anyone know if Gnome 3 can be installed on this?
Or is that a Wheezy INstall only that can use Gnome 3?
tj
AmigaOne X5000
Amiga A1222 Tabor
AmigaOne X5000
Amiga A1222 Tabor
