AmigaOS4.1 ???
ChrisH
Re: AmigaOS4.1 ???
Post by ChrisH »
nubechecorre wrote:Is there some kind of wrapper? if so, could it possible to do the same under Amiga OS? :)
I guess the answer is yes it would be *possible*. The problem (as always) is that Hyperion is trying to move the OS forwards (e.g. virtual memory (swap space), e.g. multi-core support), which means (1) they have less man-power for adding lots of backwards-compatibility kludges, and (2) it might not be possible to add those backwards-compatibility kludges without breaking some of the fancy new features (that have been or will be added).
It would probably be a LOT simpler & easier to fix the actual game, but for whatever reason that is apparently not on the cards (maybe there is a license issue?).
nubechecorre
Re: AmigaOS4.1 ???
Post by nubechecorre »
Yes, that's the right way, moving the os forward but i guess that a wrapper would let Hyperion free to do that mantaining the compatibility with all the old apps available or it wouldn't? :)
http://www.os4games.it
Sam440ep mini-itx
Classic System:
Amiga 1200
Radeon 9250 128Mb VRam
Voodoo 3 3000 16Mb VRam
DVD-RW LG Dual Layer
SoundBlaster PCI 128
Cocolino Interface Elbox
AmigaOne White Mouse
nubechecorre
Re: AmigaOS4.1 ???
about warp3d problem, on amigaworld karlos mada some interesting posts:
http://amigaworld.net/modules/newbb/vie ... r=0#618026
Sam440ep mini-itx
Classic System:
Amiga 1200
samo79
Re: AmigaOS4.1 ???
Post by samo79 »
Karlos wrote:Whilst not supported, I can confirm that at least the demo version runs on my classic 4.1 installation (was installed under OS3.x). However, it does DSI on exit.
About Heretic 2 demo on my system there are some difference between Update 2 and 3
- On Update 2 i can play it a little bit but the graphics will be shortly trashed and after a while it freeze
- On Update 3 it freeze during the loading of the initial map, so you can't start the game at all :|
amig_os
Re: AmigaOS4.1 ???
Post by amig_os »
This project is a reimplementation of WarpOS for AmigaOS 4 (work in progress):
https://github.com/Sakura-IT/ReWarp
This project is a Warp3D wrapper for use with ReWarp (work in progress):
https://github.com/Sakura-IT/ReWarp3DPPC
