Update 4 Installing Problems
ChrisH
Re: Update 4 Installing Problems
Post by ChrisH »
nubechecorre wrote:i had to unpack it on the pc with WINRAR and then copy it on a cd-rom and run it on the amiga..
Even using LHA on the Amiga can cause problems (because it fails to preserve protection flags by default). Unpacking on Windows & copying it over to the Amiga definitely won't work, sorry.
Everytime i tried to unpack the archive with unarc i got an error, it told me that the archive was corrupte
Please try redownload the archive, as already suggested. No-one else has problems unpacking the archive, so I would tend to believe UnArc when it says the archive is corrupt. And try downloading it a different way (e.g. if you downloaded it with OWB on the Amiga, then try a different web browser, or even download it on Windows).
The old (non-MUI) OWB has been known to corrupt archives downloaded from Hyperion's web site.
nubechecorre
Post by nubechecorre »
sorry for the late reply..
btw, i tried to re-download it with a pc, everything was fine, i burned it into a dvd-rw and copied on the Amiga1200. Then i unpacked it with unarc and it was fine :-)
Still i have a problem, the same problem as before, if i try to install over my system partition that already has Update4 installed, the installation window of Update4 fades away and the installation quits.. could someone check this? Re-installing the Update4 over the Update4?
http://www.os4games.it
Sam440ep mini-itx
Classic System:
Amiga 1200
Radeon 9250 128Mb VRam
Voodoo 3 3000 16Mb VRam
DVD-RW LG Dual Layer
SoundBlaster PCI 128
Cocolino Interface Elbox
AmigaOne White Mouse
JurassicC
Post by JurassicC »
Simplest way would be to fire up dopus or open the cli and copy the files by hand
As your on an A1200 just copy the files from the Directories Files_BlizzardPPC and Files_NoArch
Eg:
CD Files_BlizzardPPC
COPY clone all #? sys:
CD /
CD Files_NoArch
Then you can Run the RunInUAE installer manually
nubechecorre
ok i can still copy the files by hand, but why if i try to reinstall the update over the update, the installation window automatically close?.. is there a way to investigate this?
Sam440ep mini-itx
Classic System:
Amiga 1200
ssolie
Post by ssolie »
nubechecorre wrote:Still i have a problem, the same problem as before, if i try to install over my system partition that already has Update4 installed, the installation window of Update4 fades away and the installation quits.. could someone check this? Re-installing the Update4 over the Update4?
Installing Update 4 over Update 4 is not supported. The instructions state that you must have Update 3 installed as a prerequisite. No other scenario is supported so you are on your own.
nubechecorre
Yes indeed, i have amiga os 4.1 Update2 for Classic plus Update3 and Update4 but as i had problems with the update 4 (read the topic). When i try to reinstall Update 4 with the installer, the installation window closes itself and i'd like to know why and if there is a way to investigate this..
Sam440ep mini-itx
Classic System:
Amiga 1200
JurassicC
Post by JurassicC »
Without reading the script is probably doing a version.library check and seeing that the update 4 version.library is already there.
Try replacing the version.library from update 2 or 3 and try again.
nubechecorre
Thanks for the advice! :)
Sam440ep mini-itx
Classic System:
Amiga 1200
danbeaver
Post by danbeaver »
Gee, would have been nice to know the status of the problem: solved vs not
nubechecorre
As SSolie said, at the moment it's not possible to reinstall update4 over itself, so it is impossible to me, find a solution to this problem (RUAE). So i wll simply install RUAE as a stand alone program and not using update4.. that's all for the moment..
Sam440ep mini-itx
Classic System:
Amiga 1200
