Dragging a folder from RAM: to hard disk
samo79
Re: Dragging a folder from RAM: to hard disk
Post by samo79 »
Ok eventually i will re-test it, now that we have Update 4 i think it will work better
samo79
Post by samo79 »
After some using i can say that this problem continue to happen from time to time (not always) only when i drag a folder from a partition to another (for example)
Conversely this specific lockup never happen with a decisive cut-and-paste operation .. i don't know how to replicate exactly the issue to be able to recreate a 100% testcase but i suspect it may happen when dragging a folder that contain its .info file (the image of the icon)
Maybe ...
