SWAP broken
Deniil
Re: [BUG] SWAP broken
Post by Deniil »
Would be interesting to know where I got this VIRTUAL stuff from then. All allocations in Annotate for example I made with VIRTUAL|PRIVATE for some reason a number of years ago. I've changed it now though.
But if VIRTUAL is ignored as an AllocMem flag I guess that mem would have been PRIVATE and swappable after all.
When the migration guide was written the swapping was not yet implemented I assume, so then it wasn't 100% sure what state SHARED would have. Maybe there is some technical limitation not yet built around that makes it much easier to just lock all SHARED memory (for now?).
sundown wrote:The SWAP problem hase been fixed. My settings follow;
SWAP
Blocksize=4096
Buffers=10
Maxtransfer=7FFFFFFF (7 Fs)
Mask=FFFFFC
Not sure why the buffer setting is low, guessing default, but it does work. I can copy a 1.4GB file to RAM without problems now, crashed the system before the fix.
Just to be sure...
Are you certain that this works for you and stays after clicking OK?
Maxtransfer do work here (alhough i'd rather use FFFFFFFF [8F's] as with all my partitions), but if i set Mask to your value it always jumps back to 7FFFFFFC after clicking OK and returning to "Edit Partion details"?
Why is that and what does your Mask setting actually use then?
Any memory = 7FFFFFFF
Any memory (32 bit) =7FFFFFFC
24 bit DMA memory = ??? (greyed out here)
??? = your setting
Could it be that you accidently switched mask and maxtransfer in your post?
Thank you
edit: added information
People are dying.
How dare you!
– Greta Thunberg
