[BUG]: Notification/Ringhio-Depth gadget not working
Ringhio is preventing the depth gadget from bringing a window back if overlapping a notfication popup/window
Here's the problem.
A notification windows fades in
As soon as it is (being) drawn (visible) one can *only* bring a window to front with the depth gadget if this window overlaps the notification popup/window but *never* to the back (it simply refuses to).
While i understand that notfications are meant to be always on top this should not prevent an overlapping window from being brought back of *other* windows.
i.e. i have owb open which partly overlaps the notification popup
i have a smaller yam window open which is partly behind owb
i can never bring owb to the back (and as such yam to front) when the notfication popup is visible
ok, i could use the depth gagdet of yam, but what about a window that is completely behind owb?
Re: [BUG]: Notification/Ringhio-Depth gadget not working
Please excuse the bump as i know that all of you are busy...could anyone confirm/add to BT, please?
ChrisH
Post by ChrisH »
Yes, this appears to have an entry in BugZilla. But not sure if I am allowed to say what progress has (or has not) been made with it though.
Deniil
Post by Deniil »
Yes, this is the problem with "normal" non-stick-to-top windows being unaware of stick-to-top windows and trying to get infront of them before deciding it's time to go back on the next click. I'm sure it must have been addressed since it is a very obvious and annoying bug involving all stick-to-top windows, like AmiDock if it is configured that way.
ChrisH wrote:Yes, this appears to have an entry in BugZilla. But not sure if I am allowed to say what progress has (or has not) been made with it though.
No need for a progress report :-)
Just wanted to know if it has a number in Bugzilla.
Thanks Chris
