4.1 Calculator cosmetic bug
Steady
Post by Steady »
My first post here...
I notice that the OS 4.1 calculator in extended mode does not group the numbers properly when entering binary digits.
It helpfully sets out the number in 4-digit blocks, but the grouping is left justified when it should be right justified.
For example, assume the following number is shown in the display: 11000110111011
The calculator will show it as: 1100 0110 1110 11
It should show it as: 11 0001 1011 1011
Jason.
abalaban
Re: 4.1 Calculator cosmetic bug
Post by abalaban »
In my beta Calculator it's not the case, the digit are correctly justified.
So it seems it has been fixed meanwhile.
AmigaOne XE/G4
Steady
Post by Steady »
Thanks Abalaban.
It seems you're all one step ahead. :)
abalaban
Post by abalaban »
Steady wrote:Thanks Abalaban.
Thanks to you to take the time to report your finding here. Your report was perfect: concise and documented. It took me only a few seconds to check.
AmigaOne XE/G4
