@all
I read this topic this morning but didn't test the problem. However, this afternoon I left my computer in the middlle of typing a message in an editor and returned about an hour later. My screen was dark but moving/clicking the mouse or typing on the keyboard or hitting the keyboard "Esc" key didn't bring my screen back. Finally, I noticed that the monitor light was off and switched the monitor back on. When the screen reappeared, Odyssey was frozen but that may have been a result of all the mouse & keyboard activity.
My monitor has never turned off by itself before. I do not have the Screenblanker Prefs/Timing/Power-off delay checkmarked. I would set a "Power-off delay" delay if it turned off the computer too; otherwise I see no point. After I finish this post, I'm going to leave my computer on while I go to the store to see if I can repeat the problem.
(Auto)Switch-off monitor bug (ScreenBlanker)
Re: (Auto)Switch-off monitor bug (ScreenBlanker)
Ranger would be a good way to check the priorities of running tasks. Maybe some of them set their own priority?samo79 wrote:@nbacheNo absolutely, i didn't change the task priorities ..Have you maybe done something special about task priorities, e.g. set the video player up in priority or something?
Eventually is there any other place we can check ?
This was on my X1000... and just a curiosity, what OS4 machine are you using for this test ?
@nbache
Do i need to check the priority of the ScreenBlanker.library right ?
I now verified with SysMon and its priority is: 01
Is the same for you ?
Consider that it is the default one and i never touch it
As i said early in screen blanker prefs the "Ignore mouse when in DPMS mode" is unselected
@samo79
I tried to reproduce the "monitor shut off" problem I mentioned earlier and have not been able to reproduce it. I'm also using an X1000, so it could be possible that some hardware is less suceptible to the problem.
@xenic
Pretty possible, at this point would be interesting to verify under another Sam440 ..
Hey any OS4 betatester with Sam440 availible ?
P.S.
Xenic a question, what version of ScreenBlanker.library do you have installed ?
P.S.
Aniway many time passed and so many test done, to conclude i can reproduce the issue in this method:
1) open a video with your preferred video player, no matter what player: DvPlayer and MPlayer is exactly the same
2) then put your video in pause
3) then just waiting for some time/minutes until your monitor will be switched off, aka when your screen will be "totally black"
Now try if moving your mouse or pressing any other key in order to reactivate the screen will work on you ..
(here neither ESC seems able to resume!) .. so in this situation the only method is an hard reboot ..
I haven't read the whole thread, but did you try to let a radio stream or music loop run in the background when doing the tests?samo79 wrote:Aniway many time passed and so many test done, to conclude i can reproduce the issue in this method:
If the stream still plays when everything else has stopped working it could be reduced to either being an input problem (input.device crashed) or a problem with your gfx card returning aka everything runs fine, but your gfx card output has stopped working?
Do you mabye have the possibilty to add a second card and check the output there?
Just some more ideas i would check...
People are dying.
How dare you!
– Greta Thunberg
How dare you!
– Greta Thunberg
Not directly related with the old report, however the argument is similar ..
Since latest OS 4.1 update i have some crashes with the blanker engine ... no action by me with the system, i just leave the computer alone and after a while a GR appear ...
Crash log for task "ScreenBlankerEngine"
Generated by GrimReaper 53.19
Crash occured in module graphics.library.kmod at address 0x01A368CC
Alert number: 0x80000003
Register dump:
0: 0198E0A4 55612280 00000000 5FFFA800 2083C000 00000000 006CB100 5FFA3420
8: 00036588 00000000 20916000 011E5680 46442882 558DCCBC 2083C000 22442224
16: 00000690 00000000 00000690 02270000 3A884908 00000000 5FFFA800 0000041A
24: 00000690 00000000 32A1B000 00000008 00000000 00000000 3A882478 00000006
0: nan 323 31 0
4: 11 1277.8 30.8 0
8: 11 4.5036e+15 1277.8 30.8
12: 1601 51 0 0
16: 0 0 0 0
20: 0 0 0 1.61895e-319
24: 0 0 2.65249e-315 0
28: 0 1.35808e-312 1.3581e-312 nan
Machine State (msr) : 0x0002F030
Condition (cr) : 0x22CAADA0
Instruction Pointer (ip) : 0x01A368CC
Xtended Exception (xer) : 0x018233AC
Count (ctr) : 0x00000000
Link (lr) : 0x00000000
DSI Status (dsisr) : 0x01842B34
Data Address (dar) : 0x00000000
680x0 emulated registers:
FPU0: 0 0 0 0
FPU4: 0 0 0 0
Symbol info:
Instruction pointer 0x01A368CC belongs to module "graphics.library.kmod" (HUNK/Kickstart)
Stack trace:
native kernel module graphics.library.kmod+0x000ab4ac
native kernel module graphics.library.kmod+0x00003048
native kernel module graphics.library.kmod+0x000035e8
native kernel module intuition.library.kmod+0x00061938
native kernel module intuition.library.kmod+0x00061bac
native kernel module intuition.library.kmod+0x0006cbb0
native kernel module intuition.library.kmod+0x00021448
native kernel module intuition.library.kmod+0x000215ec
native kernel module intuition.library.kmod+0x0006c944
module IPrefs at 0x6FF33FDC (section 5 @ 0xDFB8)
native kernel module intuition.library.kmod+0x0006cc04
module LIBS:screenblanker.library at 0x6FB32C00 (section 5 @ 0x3BDC)
module LIBS:screenblanker.library at 0x6FB30A98 (section 5 @ 0x1A74)
module ScreenBlankerEngine at 0x6FA7634C (section 5 @ 0x1328)
module ScreenBlankerEngine at 0x6FA76F08 (section 5 @ 0x1EE4)
native kernel module newlib.library.kmod+0x000020ac
native kernel module newlib.library.kmod+0x00002d5c
native kernel module newlib.library.kmod+0x00002ef0
ScreenBlankerEngine:_start()+0x170 (section 1 @ 0x16C)
native kernel module dos.library.kmod+0x000255c8
native kernel module kernel+0x0003e7b4
native kernel module kernel+0x0003e7fc
PPC disassembly:
01a368c4: 39080001 addi r8,r8,1
01a368c8: 7d0903a6 mtctr r8
*01a368cc: 912a0000 stw r9,0(r10)
01a368d0: 394a0020 addi r10,r10,32
01a368d4: 912affe4 stw r9,-28(r10)
System information:
CPU
Model: AMCC PPC440EP V1.3
CPU speed: 799 MHz
FSB speed: 133 MHz
Extensions:
Machine
Machine name: Sam440EP
Memory: 1048576 KB
Extensions: bus.pci
If you search for "boingball" in these forums, you will find at least several reports of the screenblanker "boingball" module causing freezes/crashes. You might try removing the "boingball" module from the "Active" module list and place it in the "Inactive" list in ScreenBlanker prefs.samo79 wrote:Not directly related with the old report, however the argument is similar ..
Personally, I've been operating my system with the Screenblanker "boingball" module deactivated and the "Power-off" deactivated for years now.
I know, but i've disabled it long ago so it can be a problem related to this specific screensaver ...
