Transparency settings for windows (OS 4.1 FE)
emulajavi
Post by emulajavi »
Sorry if this is a newbie question…. In OS 4.1 FE… are windows supposed to have any transparency? If so, how do you enable that transparency? I mean like this
Thank you
Re: Transparency settings for windows (OS 4.1 FE)
Check out the GUI prefs program, page "Effects". Enable "Compositing effects" and experiment with the "Window transparency" sliders.
I have mine at 0, 10, and 25%, respectively.
