X1Boot Manager 1.3 Update
Hypex
Post by Hypex »
Hello every one.
I'm pleased to announce the latest update for the X1Boot Manager. The result of many months of work. This brings with it a host of new features, some bug fixes and lots of other little changes. :)
Highlights include:
  • A new setup menu: A new main menu for "Menu Setup" has been added for even easier setup of menus. This now includes the "Install Menu" option and two new options to "Import System" and "Import Volumes". These options can more easily import the current system into the menu or a selection of volumes. All you need to do is give it a name and it can do the rest!
  • Active or inactive menus: Menu entries can now be set to active or inactive. A useful feature for cleaning up the boot menu. This allows you to keep in a vault menu entries you didn't want to delete but also didn't want clogging up the menu. In cases such as using for a template.
  • Informative listings: Menu and kernel lists are now more informative. Menu lists now display kernel and release version while kernels lists now displays size, release and more.
  • New settings: There are now five new settings. These set a menu to launch on load, a file location for file dialogs, output verbosity for Loader, mount type for menu importing and default boot options for menu entries.
  • A new loader: The boot loader has been also updated this time. The output is simplified and colours changed which didn't translate well on screen. In addition it also includes a progress bar as it unpacks files as well as being able to set output verbosity to full, quick or quiet.
* New features
  • XZ compressed kernel archives now supported.
  • Saveable files location for file dialogs.
  • Menu can be chosen to launch into after loading editor.
  • Default boot options can be set for new menu entries.
  • Menu entries can be set to active or inactive to hide in boot menu.
  • Menu list now displays kernel and release version for items.
  • Kernel list now displays size, release and if modules are installed on
    current system.
  • Progress bar can now has Cancel button to cancel all further operations.
  • Main menus now have "Back" button to clearly mark going back a menu level.
  • Menu editor now has new option "Rebuild Menu" to rebuild menu list from
    menu stored on boot volume.
  • New main menu "Menu Setup" for importing volumes into menu.
  • New option "Import System" to import boot menu for current system.
  • New option "Import Volumes" to import boot menu from system volumes list.
  • Install Menu will now offer to create ramdisk if no ramdisk file selected.
  • Loader now features optional progress bar.
  • Loader output can be set to full, quick or quiet.
* Bug fixes
  • Fixed another issue where Default kernel could be blanked out.
  • Fixed issue where password check could fail due to incorrect order of SSL
    command parameters.
  • Fixed issue where duplicated archives were rejected.
  • Fixed issue where vmlinux archives were also rejected.
  • Fixed issue where missing menu file failed to rebuild menu on load.
* Other changes
  • Now allows three password attempts before giving up.
  • Now uses kernel key storage facility to privately store credentials.
  • Option to "View Menu" in Menu editor will filter out inactive items.
  • Option to "Copy Entry" in Menu editor will now open Entry editor.
  • Option to "Add Entry" in Menu editor will now use default kernel instead
    of direct kernel when Default is selected as kernel.
  • Option to "Edit Entry" in Menu editor now shows current settings.
  • Selecting a menu entry from "View Menu" will now open Entry editor.
  • Kernel list now caches info displayed in table.
  • Saving menu will now backup existing menu list.
  • Main menu option "Install Menu" moved into new "Menu Setup" menu.
  • Main menu option "Install Menu" can now generate ramdisk if needed.
  • Images installed are now date stamped to source image date.
  • Now runs depmod after installing modules to generate any map files needed.
  • Installing kernel archive will update ramdisk to match if present.
  • Updated documentation to match current version.
  • Changed package Architecture to all so both ppc32 and ppc64 are supported.
  • Relaxed installer confirming boot volume on package update.
  • Removed garish colour scheme in loader and simplified output.
Tiny tutorial:
Here's just a tiny tutorial with updated instruction guides for using the new Menu Setup options and explaining the new settings.
Menu Setup: Menu setup and importing volumes. This will bring up the menu setup options. From here you can install menu, import system or import volumes.
  • Install Menu: Install boot menu for current system. This will quickly install a boot menu to get you started for the current system. You will be asked for a menu entry name, defaulting to Linux release name. Then you will be asked to choose an X1000 Kernel Binary, which can be a vmlinux or zImage. Finally, your root mount will be checked to see if requires a ramdisk, and if it does it will also ask you to choose an X1000 Kernel Ramdisk. If you need one created then it will offer to create it if you make no file selection. Provided everything passes verification the kernel image and ramdisk image if needed will then be installed to the X1Boot volume and a menu entry added. This will now be ready to boot from.
  • Import System: Import boot menu from current system. This will easily import the current system into the menu provided a matching kernel is already installed. You will be asked for a menu entry name, defaulting to Linux release name. This will now import the system into the menu using running kernel and set boot options to current command line. Your root mount will be checked to see if requires a ramdisk, and if a ramdisk is needed it will be created on the fly. The Edit Entry editor will now open to make any final adjustments.
  • Import Volumes: Import boot menu from system volumes. This will easily import a selection of system volumes into the menu. You will first need to give root access to scan system devices. You will then be asked to chose what kernel to use in the new menu entries. Your system will scanned for existing Linux volumes and a volume list will be presented with each entry displaying device, label, size, filesystem and UUID. From here you can select what volumes to import and will be asked an entry name for each, defaulting to partition label, if any. This will import the volumes into the menu one by one and set boot options accordingly based on the Mounter and Boot option settings. If a ramdisk is needed it will be created on the fly. The Edit Entry editor will now open to make any final adjustments to the imported entries.
Edit Settings: Edit kernel installation settings. This will bring up the full settings editor. From here you can set compression format, compression level, ramdisk activation, default kernel, duplicate files, launch menu, file location, loader output, mounter type and default boot options.
  • Launch: Launch into menu immediately after loading. Will optionally set a main menu to immediately launch into when the X1Boot Manager is opened. Default is standard Main Menu.
  • Location: Current file location to install from. Will set a file location to install from in file dialogs. Location will be relative to home user folder if location is under home folder, so current home folder is portable across systems. Default is "*".
  • Loader: Boot loader output verbosity. Options are Full, Quick or Quiet. Full will print banner, files loading with progress bar and binary type launching; Quick will only print files loading; and Quiet will leave screen blank until kernel launches. If any error occurs it will be printed to screen regardless of setting. Default is Full.
  • Mounter: Root mount device type. This sets the preferred root mount type to use when importing system volumes with the Import Volumes option from Menu Setup. Options are Device, Label or UUID. Label or UUID will activate ramdisk on imported menu entries. If Label or UUID is missing when importing volumes it will fall back to Device. Default is Device.
  • Boot: Set default boot options on command line. This will set default boot options when adding new menu entries. It affects the Add Entry and Import Volumes options. In the later case it will be prepended to boot command line. Default is "console=tty0".
Download:
https://drive.google.com/file/d/1TKn3b4 ... sp=sharing
Re: X1Boot Manager 1.3 Update
Wow 😮 Great! Screenshots please.
Hypex
Post by Hypex »
xeno74 wrote: Wed May 07, 2025 8:03 pm Wow 😮 Great! Screenshots please.
Thanks! :) I don't believe it, I forgot the screen shots! :o Well here's some I took earlier! :D
Main Menu:
View Images:
Loader:
Hypex
Post by Hypex »
Looks like Christmas has come earlier than July in the last shot. :P
Menu Setup:
Import Volumes:
Edit Settings:
sailorMH
Post by sailorMH »
@Hypex
after playing with Pegasos 2 CPU upgrade I finally have time to my fist AmigaOS 4 machine - X1000.
I want re-install AmigaOS with fresh installation upd3 and also reorganize a little linux distributions.
Your X1boot manager looks very nice ( CFE commands are boring sometimes ;-) ). Unfortunatelly download link does not work now.
Please, can you share X1Boot Manager 1.3 again? ( I have only ver 1.0 ).
Many thanks!
Hypex
Post by Hypex »
@sailorMH
Thanks. Hope it will be useful. Sorry, I'm not sure what is going on with the link. I checked it and it works at my end. I selected shareable again if it helps. But my account is full so may need another location. Unfortunately the forums only support images or I would have stored here. Dropbox may be better. I'll investigate.
sailorMH
Post by sailorMH »
@Hypex
thank you for information - I downloaded suceesfully from work.
At home I have problem - probably my provider isuue
All is OK now, thank you!
Hypex
Post by Hypex »
Ah that's good then. I was recently put on CGNAT that interferes with FTP. So had to take myself off that but don't know what else would interfere.
If you have any issues I'll expect some feedback or complaints if they are bad issues. :-D
One issue there is I found out, or limitation, is that the boot volume needs to be on the same drive as AmigaBoot. This likely caused early issues with boot menus going missing. My X1000 only had one HDD for years and only when I added an SSD I found an issue. AmigaBoot will only see and boot from the first HDD. I installed a fresh OS4 volume onto the SSD and it didn't show up. No wonder I went back to my A1/XE in the past that doesn't have these limitations. :-)
sailorMH
Post by sailorMH »
Hypex wrote: Tue Feb 03, 2026 1:36 am One issue there is I found out, or limitation, is that the boot volume needs to be on the same drive as AmigaBoot. This likely caused early issues with boot menus going missing. My X1000 only had one HDD for years and only when I added an SSD I found an issue. AmigaBoot will only see and boot from the first HDD. I installed a fresh OS4 volume onto the SSD and it didn't show up. No wonder I went back to my A1/XE in the past that doesn't have these limitations. :-)
That is not limitation of your X1Boot manager, it is limitation of X1000 firmware. CFE see only two SATA ports: port 0 normally occupied by DVD and port 2 occupied by HDD.
I am not sure if X1000 firmware see disk in internal IDE controller or in PCI SiI3x1x controller. I will test it. Manual says:
SATA and IDE (PATA) hard drives are usually called "ideM.N:", where "M" is the controller number and "N" is the disk
number. Sometimes, you can add a comma followed by a partition name or number afterwards. For example, "ide0.0,dh0:"
would access partition "dh0:" on an AmigaOS disk on the X1000’s SATA 0 port.
It looks like there can be more controllers than internal SATA.
Hypex
Post by Hypex »
sailorMH wrote: Tue Feb 03, 2026 8:09 am That is not limitation of your X1Boot manager, it is limitation of X1000 firmware. CFE see only two SATA ports: port 0 normally occupied by DVD and port 2 occupied by HDD.
I'm not sure what's up with that. I've looked in the device tree and can only find block devices for two SATA units. But CFE can read and boot off USB. There was meant to be an update to AmigaBoot so it could read ISO9660 off USB but it just doesn't work on the X1000. People have commented that the X1000 could boot OS4 off USB decades ago but something is broken. AmigaBoot scans and looks for block devices in the tree to load its menus from but it only finds two block devices in my tests. Any other block devices are "blocked." :-?
IMHO CFE was designed to be too limited. It cannot scan controllers without being told and although it could be programmed to do it the default boot scripts don't bother. So it's inferior to UBoot in that regard. It's somewhat easier to manage for developers by just needing to compile a compatible OpenFirmware binary. But CFE is some kind of hack with OF hacked into the backend of it.
That suggests it does support it. It can read and list files from different partitions. I don't recall if I tested an IDE HDD from CFE.
There is actually another issue, that again is down to CFE, and that is memory. Like UBoot the memory available at boot is limited to 16MB or so and leaves around 14MB free for use. An issue with this is that anything going over will break and this includes AmigaBoot. So AmigaBoot wil either throw an error or simply stall. Sometimes end up a CFE prompt. But it's not consistent. So if there is a GZ kernel and ramdisk, they will be too large and break the memory barrier. Problem is I'm not sure how to check for this as I don't know the exact figure that will break the limit. But if most people leave the settings at default and want a ramdisk it just won't work and won't always indicate why. In fact now the kernels are getting so large that even a solo kernel could break on load.
The only solution I can see to this is to write my own loading routines. And just use AmigaBoot to load a file list. I plan to address this later but it means I have to do the job of AmigaBoot loading the files directly. The other solution, and what I do right now, is to simply use XZ compression which works fine to compress both kernel and ramdisk. But, XZ is so slow to compress, so I wouldn't expect everyone to wait around for 2 minutes or more for a few small files to compress. :-)
