How to activate ttyUSB0?
How can I activate 'ttyUSB0' in PPC Linux distros? In Ubuntu18 it is enough to plug in an USB device using that (e.g. a USB-SER adapter), the ttyUSB0 appears automatically into /dev. But that does not happen with any of the PPC distros (MintPPC, Fienix, Ubuntu16) I tested.
Re: How to activate ttyUSB0?
Roland wrote: Sat Apr 27, 2024 6:31 pm How can I activate 'ttyUSB0' in PPC Linux distros? In Ubuntu18 it is enough to plug in an USB device using that (e.g. a USB-SER adapter), the ttyUSB0 appears automatically into /dev. But that does not happen with any of the PPC distros (MintPPC, Fienix, Ubuntu16) I tested.
Please add console=ttyS0,115200 to the boot arguments.
Further information: X5000 via null modem RS-232 serial cable
xeno74 wrote: Sun Apr 28, 2024 10:46 am
I added "console=ttyS0,38400", but that did not help...
It is _not_ the RS-232 port I want to use but read the MCU debug output (connector on motherboard) via an USB port. The baudrate for it is 38400.
With Ubuntu18 (on a portable), I can access the MCU simply with "sudo screen /dev/ttyUSB0 38400" in a terminal, nothing else is needed.
Roland wrote: Sun Apr 28, 2024 12:25 pm It is _not_ the RS-232 port I want to use but read the MCU debug output (connector on motherboard) via an USB port. The baudrate for it is 38400.
I am sorry, I don't have any experiences with the MCU supervisor interface.
I only know that it provides voltage and temperature monitoring for the CPU.
Setup:
  • 38400 Baud
  • 8 bit data
  • No Parity
  • 1 Stop bit
  • No Flow Control
xeno74 wrote: Mon Apr 29, 2024 8:31 pm
All that is probably meaningless what comes to this issue... The MCU is just one possible target for the adapter cable. I think he problem is that OS does not communicate with the adapter (and the chip used in it) properly. Is there missing a driver from the kernel?!
The product (ADA954 3.3V TTL USB-serial adapter cable) is this:
https://www.adafruit.com/product/954htt ... roduct/954
"lsusb" tells that it has the PL2303 chip:
Bus 002 Device 003: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port
Hi Roland,
Kernel 5.10.208 config:
CONFIG_USB_SERIAL_PL2303=m
# CONFIG_USB_SERIAL_CP210X is not set
Kernel 6.9-rc6 config:
Have you already tested it with installed kernel modules? (PL2303)
If yes, maybe the CP210X kernel module is missing.
xeno74 wrote: Tue Apr 30, 2024 5:02 am Have you already tested it with installed kernel modules? (PL2303)
No, I did not remember there were also those modules which are not compiled in the kernel...
I copied the whole bunch to the lib/module, and now it's working! Thank you for the tip :-).
But is better to have on disk only the modules you know to need? Are they eating memory when the machine is booted, or are they loaded only if some device try to call them?
>> help
 command                    description
 help                       Print this help list
 id                         Identify (report h/w and f/w revisions)
 id date                    Identify (report h/w and f/w revisions build date)
 p                          Power up all supplies
 s                          Shut down all supplies
 q                          Toggle printing
 v                          Print voltages and temperatures
OK
>> id
Cyrus Plus
MCU Firmware Version 2.5
Hardware Version 2.2
CPLD Version 1.0
Dual Ethernet devices fitted.
Release Build
OK
>> v
-       vcc_cpld: 3.32
-  vdd_3v3_xorro: 3.31
-    vdd_1v0_idt: 1.01
-  vdd_1v0_xorro: 1.00
-        vdd_3v3: 3.35
-        vdd_2v5: 2.50
-    vdd_1v2_eth: 1.20
-         vdd_pl: 1.03
-         vdd_ca: 1.20
-         vdd_cb: 1.19
-    vdd_ddr3_io: 1.49
-    vdd_xvdd_fl: 1.82
-       pcb_temp: 41 deg C
-       cpu_temp: 59 deg C
-       pex_temp: 59 deg C
-        FAN RPM: 0
OK
Roland wrote: Tue Apr 30, 2024 8:40 am Are they eating memory when the machine is booted, or are they loaded only if some device try to call them?
They are only loaded once the devices have been recognized.
