VAPOR-X Radeon HD5870
I have successfully tested the VAPOR-X Radeon HD5870 1GB GDDR5 PCI-E DUAL DVI-I/HDMI/DP with my AmigaOne X1000.
Pictures:
Re: VAPOR-X Radeon HD5870
GLmark2 with the VAPOR-X Radeon HD5870 1GB GDDR5 PCI-E DUAL DVI-I/HDMI/DP in my AmigaOne X1000:
Score: 2793
X5000/40 with an AMD Radeon HD 6970:
GL_RENDERER: AMD CAYMAN (DRM 2.50.0 / 6.10.0-rc1-powerpc64-smp, LLVM 12.0.1)
GL_VERSION: 3.1 Mesa 22.2.4
glmark2 Score: 4148
Hypex
Post by Hypex »
So what's special about this card? Is it a high end model?
Hypex wrote: Sat Jun 29, 2024 9:14 am So what's special about this card? Is it a high end model?
My old card doesn't work anymore so I have needed a new one. The new card needs less power and it is very fast.
Hypex
Post by Hypex »
Okay that makes sense. Good find.
xeno74 wrote: Sat Jun 01, 2024 1:05 pm X5000/40 with an AMD Radeon HD 6970:
glmark2 Score: 4148
X5000/40 with an AMD Radeon HD 6870:
GL_RENDERER: AMD BARTS (DRM 2.50.0 / 6.13.0-rc1-powerpc64-smp, LLVM 12.0.1)
glmark2 Score: 3887 Second test: 3942
