Being a vivid and enthousiastic user of the Find-command, I notice a dire need for some improvements. I would like to see 2 checkboxes about the following aspects:
- Skip links
- Skip .info
Being a heavy user of (soft-)links, looking for a certain file can generate a lot of entries all pointing to one and the same file and no way way to find out the actual location of that entry.
Likewise, with a lot of files having an icon of their own, the list contains these entries without any actual usefull contribution.
I hope this would be possible.
Regards,
OldFart
Feature request for 'Find'-command
X5000, stored.
Dead MicroA1
RaspBerry Pi 2B, 3B, 4B/4Gb, 4B/8Gb, 5B
OrangePi 5+ 8Gb
ACER Aspire Windows 10
Dead MicroA1
OrangePi 5+ 8Gb
Re: Feature request for 'Find'-command
I agree. I find that Find will get stuck on links in a recursion, excusing the pun. Then will give an error about a file it found not existing. Huh?
I suspect it needs to check the file type and read the link. Internally it looks like treating the file generically is failing. So it cannot transparently use DOS to open it and have DOS resolve it.
I would add that it needs better selection. I mean, if you select drawer to scan, it still wants to scan all volumes! This isn't very logical to me. So I always have to deselect all and select what volume I want. Or drag it in to search in it.
If Find had options to select only what drawer is active, say in tooltypes, that would alleviate it.
