IPrefs/Workbench crash on 68000
kolla
Post by kolla »
With OS 3.2.1, setting any sort of pattern/image for "Screen" (not for Workbench or for Window) in WBPrefs, will cause 8000 0003 on 68000 systems when selecting "ResetWB" from the Tools menu.
Steady
Re: IPrefs/Workbench crash on 68000
Post by Steady »
Thanks kolla. I'll have a look and see if I can replicate it.
Steady
Post by Steady »
I can see the same thing under a plain 68000 CPU with screen a picture for a screen background and I don't even have to select ResetWb. I will raise a bug.
kolla
Post by kolla »
Can confirm that this is fixed in the 3.2.2 updated.
