LHA archives on Linux
AlfredOne
Post by AlfredOne »
Hello,
I'm trying to build adtools to cross-compile for AmigaOS4.1 on Linux Mint.
I have a problem extracting the "base.lha" archive contained in SDK 53.34.
The base.lha contains the following empty directories:
- Include/include_h/exec
- Include/include_h/expansion
- Include/include_h/utility
On AmigaOS4 empty directories are extracted correctly as empty directories.
On Linux Mint the lha command fails to extract the exec directory and all subsequent ones.
I tried to use 7z and it goes a little better: it manages to extract everything correctly except the empty directories which it interprets as a file of size 0 instead.
Anyone know a way to more reliably extract archives on Linux?
Amiga500 Kickstart1.3
AmigaONE X1000 - 2GB RAM
  • Radeon R9-280X 3GB
  • Radeon HIS4670 1GB DDR3
  • Radeon RX550
My site: https://project4a.eu
Re: LHA archives on Linux
Which lha command/program does linux mint use?
Have you tried lhasa?
sudo apt install lhasa
It's just for unpacking, but maybe works for you
AlfredOne
Post by AlfredOne »
lhasa was the first tool I used and opened a bug on the github site:
https://github.com/fragglet/lhasa/issues/37
This is the answer from the author of lhasa:
"The problem is that the item that should have been a directory (type "lhd") is erroneously stored as a regular file (type "lh0"), due to a bug in whatever program created the LHA file. The item does not have a filename; it only has a directory name. Lhasa treats a file without a filename as a fatal error."
So it seems that the program used to create the AmigaOS SDK lha archive has a bug.
Note: despite the bug, on AmigaOS4 I am able to extract empty directories correctly.
  • Radeon RX550
walkero
Site Admin
Post by walkero »
@AlfredOne
Try to compile a proper version of lha
    git clone https://github.com/jca02266/lha.git;
    mkdir build;
    cd lha;
    autoreconf -vfi;
    cd ../build;
    ../lha/configure --prefix=/usr;
    make;
    make install;
That's what I am doing in my docker images for the cross-compiling environments I use.
https://github.com/walkero-gr/docker4AmigaVBCC
https://github.com/walkero-gr/AmigaGCConDocker
If you develop or want to develop for AmigaOS 4.x, then join us at OS4Coding.net
rjd324
Post by rjd324 »
Linking this to https://github.com/sba1/adtools/issues/112. I came across the same issue.
Just for completeness.
Hypex
Post by Hypex »
AlfredOne wrote: Wed Jan 12, 2022 5:34 pm So it seems that the program used to create the AmigaOS SDK lha archive has a bug.
This would explain a lot. I have found extracting LhA files on Linux doesn't work on newer archives or archives I pack from OS4. I tend to use DOpus but they always tend to break. It looks like a crash. I open an archive and it just quits when reading it.
Doesn't matter what I try. Rarely do any LhA files fork for me in Linux. Could be -lha5- or -lha6- but Linux doesn't like them.
It's really annoying as I always want to read an LhA archive on Linux a lot. :-)
Hypex
Post by Hypex »
walkero wrote: Wed Jan 19, 2022 6:28 pm Try to compile a proper version of lha
Thanks. I'll give this a shot.
