Want to buy AOS4.1 final cd for x1000 (solved)
msalcedo
Post by msalcedo »
Title says it all.
I want/need to have the AOS 4.1 final cd for the X1000
FYI, when I bought this wonderful used x1000, I did not get the CD, just a working hard drive..
I tried to find this on the Hyperion web site, but I was unable locate. (sigh)
Please any info or leads?
Michael
msalcedo
Re: Want to buy AOS4.1 final cd for x1000
Post by msalcedo »
Thanks for the reply.
That web site doesn't have what I need, but
I have my Classic Hyperion OS4.1 cd and
AOS 4.1 for 440 and
My X5000 version
There is no version available for the X1000 (i guess) it ONLY came with the machine.
My seller hasn't responded to my email.. (sigh)
Raziel wrote: Fri Dec 31, 2021 11:37 am https://www.amigaos.net/content/4/where-buy
Hmm?
Just follow the links and see what they have in stock.
I just did a quick look and alinea seems to have it:
https://www.amiga-shop.net/Amiga-Softwa ... ::689.html
You can choose to buy the X1000 version near the price.
Also, if you are unsure, just write them a mail, they have always been helpful in the past
msalcedo
Re: Want to buy AOS4.1 final cd for x1000 (solved)
Post by msalcedo »
Many Thanks!
I didn't try the EU dealers, but it seems they do have it and in stock!
Shipping is almost as much as the item itself.. sigh
Raziel wrote: Sat Jan 01, 2022 10:04 am Hmm?
msalcedo wrote: Sat Jan 01, 2022 9:43 amThere is no version available for the X1000 (i guess) it ONLY came with the machine.
There was/is definitely a version of FE for X1000.
Well, it's New Year's ... :-)
Hope it works out for you with ALinea.
I don't suppose you are able to get the registration number from the previous owner, even though you didn't get the CD? If you can get the registration transferred, which you are entitled to, you would be able to download a fresh copy of your OS ISO from the Hyperion website after logging in.
msalcedo
Post by msalcedo »
@Niels
Thanks for the good advice/info and wishes!
order in but Alinea is on holiday..
nbache wrote: Sat Jan 01, 2022 4:30 pm
