dhewm3 (Doom3)
dhewm3 (Doom3)
Great news: Bug "No text on BigEndian" fixed
Further information about dhewm3: https://dhewm3.org
Re: dhewm3 (Doom3)
I successfully compiled it today.
Download: dhewm3-1.5.1-linux-powerpc.tar.gz.
It works on Fienix and MintPPC.
For Fienix: You need the package ibjpeg9_9d-1_powerpc.deb. Please install it with dpkg -i before you start dhewm3.
Re: dhewm3 (Doom3)
Screenshot of the new fixed version of dhewm3:
Re: dhewm3 (Doom3)
Display FPS, GPU, CPU, TEMP etc:
GALLIUM_HUD=simple,fps,cpu ./dhewm3
GALLIUM_HUD=GPU-load,cpu0+cpu1+cpu2+cpu3,fps,sensors_temp_cu-radeon-pci-0100.temp1 ./dhewm3
Re: dhewm3 (Doom3)
I also tested dhewm3 with ultra quality settings on my Raspberry Pi 400 with an overclocked quad core CPU (4x 2.2GHz) and an overclocked VideoCore VI GPU and it isn’t as fast as on my AmigaOne X1000 and AmigaOne X5000.
Re: dhewm3 (Doom3)
I compiled it for the old Ubuntu 16.04 today.
Download: dhewm3-1.5.1-ubuntu16.04-powerpc.tar.gz
I had to compile a new version of openal-soft as well because it doesn't compile with the default installed openal devel files.
Re: dhewm3 (Doom3)
Hi christian.
How do you start the dhewm3 file?
thanks
Peter
Re: dhewm3 (Doom3)
musa wrote: Wed Apr 21, 2021 6:05 pm Hi christian.
thanks
Peter
Hi Peter,
You can start it with ./dhewm3 but you'll need the game data from a Doom3 installation.
Further information: How to Install
I copied the .pk4 files to /home/christian/.local/share/dhewm3/base.
Re: dhewm3 (Doom3)
xeno74 wrote: Wed Apr 21, 2021 6:15 pm
thanks
Peter
Hi Peter,
I found out. Forgot the base folder. Its running :)
Peter
Re: dhewm3 (Doom3)
caseycullen wrote: Mon Apr 26, 2021 8:50 pm dhewm3_1.5.1.fienix.deb (includes engine only) and doom3_1.5.1.fienix.deb (includes app menu launcher, setup scripts and demo) have been added to the Fienix repo. The doom3 package will play the "shareware"/"demo" version until you copy the full game data files; to do this, copy your "base" directory to ~/.local/share/dhewm3.
Let me know if you have any issues.
-Casey
Hi Casey,
Many thanks! It works without any problems. Great! :-)
