Bug in FE Update 2 Date Command
Re: Bug in FE Update 2 Date Command
@Rigo
I see it as a possible push towards technological evolution.
Can AmigaOS evolve to prevent components from being overwritten or block those that were overwritten from executing .?
If so then Enhancer and anything else would also have to evolve to find a niche in an environment that prevented component from being overwritten or executing .
:D
Rigo
Post by Rigo »
It's highly unlikely unless AmigaOS adopts some sort of database of distributed components (akin to a registry) where every component is checked for version number before being run.
Well, you can imagine what kind of rapturous applause this is going to receive, can't you...
Needless to say, it will certainly slow that system down, let alone anything else.
No, this problem needs to be weeded out at the root cause. My advice is to simply not overwrite system components, and the problem is gone.
Simon
Amiguy
Post by Amiguy »
@broadblues
Thank you very much for your tip ;) . I will try your solution as soon as possible.
Amiga 1200 2 MB Chip - Turbo 1230 32 MB Fast - CF 128 GB - Indivision MK3 - GOEX Drive - Roms & WB 3.2
Amiga Forever 7 Plus Edition which emulates AmigaOS4.1 FE Classic
AmigaOne X5000 2 GHz / 8 GB Ram - Radeon R7 250X - Sound Blaster Audigy FX 5.1 SBX - AmigaOS4.1 FE and Linux Fienix 3.0
redfox
Post by redfox »
Deleted
