Exchange window positioning
amifrog
Re: Exchange window positioning
Post by amifrog »
Well, then we name that tooltype 'SavePositionTo=' and put some parenthesis around.😄
When the user activates it, then the position is saved.
As i said, adding one or two tooltypes in a smart way could do the trick.
I don't know what the current menu looks like; often the systems tools haven't got even an 'About...' menu with version or build informations. Which was styleguide since ages, IIRC.
So adding a menu item for that pos saving is an option. If it is applied in a wider range as standard.
Having this little function title button on every tiny window even in one multiwindow application (i'm pointing at you, Codebench) is certainly wrong.
