Kernel 5.9
Re: Kernel 5.9
Skateman wrote: Sat Aug 15, 2020 2:59 pm Kernel 5.9 Alpha6 running fine on the AmigaOne X5000
Thanks a lot for testing the alpha6! :-)
Have a nice weekend!
Re: Kernel 5.9
The RC1 of kernel 5.9 is available for the X1000 and X5000.
Issues:
  • Virtual e5500 QEMU machine with a VirtIO-GPU: The issue with the VirtIO-GPU still exists. Therefore we still need the virtio_gpu patch.
  • X5000: We still need the dpaa-v1 patch because of the DPAA issue on Ubuntu 16.04.
Download: linux-image-5.9-rc1-X1000_X5000.tar.gz
Re: Kernel 5.9
Kernel 5.9 RC1 up and running on the AmigaOne X5000
Big picture http://www.skateman.nl/wp-content/uploa ... 210603.png
Re: Kernel 5.9
Skateman wrote: Mon Aug 17, 2020 8:08 pm Kernel 5.9 RC1 up and running on the AmigaOne X5000
Many thanks for testing the RC1! :-)
Re: Kernel 5.9
K5.9RC1 up and running fine. Thanks
Re: Kernel 5.9
acefnq wrote: Tue Aug 18, 2020 10:49 am K5.9RC1 up and running fine. Thanks
Thank you! :-)
Great news because of the issue with the VirtIO-GPU.
Gerd Hoffmann wrote: It is fixed in drm-misc-next (commit 51c3b0cc32d2e17581fce5b487ee95bbe9e8270a).
Will cherry-pick into drm-misc-fixes once the branch is 5.9-based, which
in turn should bring it to 5.9-rc2 or -rc3.
take care,
Gerd
Link to drm-misc-next (commit 51c3b0cc32d2e17581fce5b487ee95bbe9e8270a)
Re: Kernel 5.9
I compiled a new kernel with the latest DRM misc updates today.
git clone git://cgit.freedesktop.org/drm/drm-misc.git a
Our patch is included in these updates.
Download: linux-image-5.9-rc1-2-X5000.tar.gz
This kernel works with the VirtIO-GPU in a virtual e5500 QEMU/KVM HV machine on my X5000.
Unfortunately I can only use the VirtIO-GPU (Monitor: Red Hat, Inc. 8") with a resolution of 640x480. If I set a higher resolution then the guest disables the monitor. I can use higher resolutions with the stable kernel 5.8 and the VirtIO-GPU.
I reported this issue to the kernel developers today. Link: [Virtual ppce500] virtio_gpu virtio0: swiotlb buffer is full
Re: Kernel 5.9
Gerd released a patch because of the resolution issue with the VirtIO-GPU yesterday.
diff --git a/drivers/gpu/drm/virtio/virtgpu_drv.h b/drivers/gpu/drm/virtio/virtgpu_drv.h
index 9ff9f4ac0522..4ab1b0ba2925 100644
--- a/drivers/gpu/drm/virtio/virtgpu_drv.h
+++ b/drivers/gpu/drm/virtio/virtgpu_drv.h
@@ -138,6 +138,7 @@ struct virtio_gpu_output {
 	int cur_x;
 	int cur_y;
 	bool enabled;
+	bool needs_modeset;
 #define drm_crtc_to_virtio_gpu_output(x) \
 	container_of(x, struct virtio_gpu_output, crtc)
diff --git a/drivers/gpu/drm/virtio/virtgpu_display.c b/drivers/gpu/drm/virtio/virtgpu_display.c
index 2c2742b8d657..6c26b41f4e0d 100644
--- a/drivers/gpu/drm/virtio/virtgpu_display.c
+++ b/drivers/gpu/drm/virtio/virtgpu_display.c
@@ -123,6 +123,17 @@ static int virtio_gpu_crtc_atomic_check(struct drm_crtc *crtc,
 static void virtio_gpu_crtc_atomic_flush(struct drm_crtc *crtc,
 					 struct drm_crtc_state *old_state)
+	struct virtio_gpu_output *output = drm_crtc_to_virtio_gpu_output(crtc);
+	 * virtio-gpu can't do modeset and plane update operations
+	 * independant from each other.  So the actual modeset happens
+	 * in the plane update callback, and here we just check
+	 * whenever we must force the modeset.
+	if (drm_atomic_crtc_needs_modeset(crtc->state)) {
+		output->needs_modeset = true;
 static const struct drm_crtc_helper_funcs virtio_gpu_crtc_helper_funcs = {
diff --git a/drivers/gpu/drm/virtio/virtgpu_plane.c b/drivers/gpu/drm/virtio/virtgpu_plane.c
index 52d24179bcec..65757409d9ed 100644
--- a/drivers/gpu/drm/virtio/virtgpu_plane.c
+++ b/drivers/gpu/drm/virtio/virtgpu_plane.c
@@ -163,7 +163,9 @@ static void virtio_gpu_primary_plane_update(struct drm_plane *plane,
 	    plane->state->src_w != old_state->src_w ||
 	    plane->state->src_h != old_state->src_h ||
 	    plane->state->src_x != old_state->src_x ||
-	    plane->state->src_y != old_state->src_y) {
+	    plane->state->src_y != old_state->src_y ||
+	    output->needs_modeset) {
+		output->needs_modeset = false;
 		DRM_DEBUG("handle 0x%x, crtc %dx%d+%d+%d, src %dx%d+%d+%d\n",
 			  bo->hw_res_handle,
 			  plane->state->crtc_w, plane->state->crtc_h,
Link: [1/2] drm/virtio: fix unblank
Re: Kernel 5.9
I compiled a new RC1 with Gerd's and our patch today. With these patches, the VirtIO-GPU works without any problems. I can use higher resolutions again. :-)
Download: linux-image-5.9-rc1-3-X5000.tar.gz
Screenshot of the RC1-3 with the VirtIO-GPU in a virtual e5500 QEMU/KVM HV machine on my X5000:
Re: Kernel 5.9
Kernel 5.9 RC1-3 up and running fine on the AmigaOne X5000
Big picture http://www.skateman.nl/wp-content/uploa ... 210758.png
