Kernel 5.8
Re: Kernel 5.8
FYI because of the KVM-PR issue:
Nicholas Piggin wrote: Hey, thanks for debugging it and reporting. I'm looking into it, will
try to get a fix soon.
Nick
Re: Kernel 5.8
Nicholas Piggin has released a patch:
Nicholas Piggin wrote: Does this patch fix it for you?
The CTR register reload in the KVM interrupt path used the wrong save
area for SLB (and NMI) interrupts.
Fixes: 9600f261acaaa ("powerpc/64s/exception: Move KVM test to common code")
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
 arch/powerpc/kernel/exceptions-64s.S | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/kernel/exceptions-64s.S b/arch/powerpc/kernel/exceptions-64s.S
index e70ebb5c318c..fa080694e581 100644
--- a/arch/powerpc/kernel/exceptions-64s.S
+++ b/arch/powerpc/kernel/exceptions-64s.S
@@ -270,7 +270,7 @@ BEGIN_FTR_SECTION
 END_FTR_SECTION_IFSET(CPU_FTR_CFAR)
 	.endif
-	ld	r10,PACA_EXGEN+EX_CTR(r13)
+	ld	r10,IAREA+EX_CTR(r13)
 	mtctr	r10
 BEGIN_FTR_SECTION
 	ld	r10,IAREA+EX_PPR(r13)
@@ -298,7 +298,7 @@ END_FTR_SECTION_IFSET(CPU_FTR_HAS_PPR)
 	.if IKVM_SKIP
 89:	mtocrf	0x80,r9
 	mtctr	r10
 	ld	r9,IAREA+EX_R9(r13)
 	ld	r10,IAREA+EX_R10(r13)
2.23.0
Re: Kernel 5.8
I released the RC1 of kernel 5.8 for the X1000 and X5000 today. The issue with KVM-PR has been solved. :-)
Download: linux-image-5.8-rc1-X1000_X5000.tar.gz
Re: Kernel 5.8
Kernel 5.8 RC1 breaks the onboard DPAA network adapter of the AmigaOne X5000/20
Big picture http://www.skateman.nl/wp-content/uploa ... 234930.png
Reverting back to Alpha 4 made the DPAA network adapter working again.
Re: Kernel 5.8
Skateman wrote: Mon Jun 15, 2020 8:56 pm Kernel 5.8 RC1 breaks the onboard DPAA network adapter of the AmigaOne X5000/20
Thanks a lot for testing the RC1! :-)
Strange thing with the DPAA ethernet. I didn’t find any DPAA changes between the alpha4 and the RC1. I only found one DPAA2 commit between the alpha4 and the RC1 but our X5000 has DPAA1. The kernel developers expect a bisect from us but I can’t do it alone because the DPAA ethernet has never worked reliable on my X5000/20 and X5000/40. We need to create about 13 kernels for the bisect. I can do that but I need you for testing them on your X5000. It’s a lot of work. What do you think? Shall we do it?
Re: Kernel 5.8
For me its key to have the onboard ethernet adapter working again.
I also think that most of us did not tried to unplug the inserted pci networkadapter so the X5K was using only its onboard adapter.
If thats the solution i dont know... but i wont revert back to using a pci nic.
That leaves me to the only possible option, and i am willing to test all kernels needed :-)
Re: Kernel 5.8
Skateman wrote: Tue Jun 16, 2020 5:44 pm I also think that most of us did not tried to unplug the inserted pci networkadapter so the X5K was using only its onboard adapter.
I did it because MorphOS on my X5000/20 doesn't need an additional PCI network card. I successfully downloaded the RC1 with the onboard ethernet (p50x0eth.device:0) on MorphOS today and after unpacking the package I was able to copy the RC1 kernel to the Fienix-boot partition. Then I rebooted the X5000/20 and started Fienix with the RC1 successfully.
Screenshots:
I also tested the DPAA Ethernet with the stable kernel 5.7 and Darren's new cyrus-p5020.dtb on my X5000/20 but without any success.
Error messages:
Jun 16 18:24:45 Fienix NetworkManager[3823]: <info>  [1592349885.1417] device (eth0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
Jun 16 18:24:45 Fienix NetworkManager[3823]: <info>  [1592349885.1550] device (eth1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
Skateman wrote: Tue Jun 16, 2020 5:44 pm That leaves me to the only possible option, and i am willing to test all kernels needed :-)
I will compile the first test kernel tomorrow.
Re: Kernel 5.8
OK Skateman, let's test them ....
git clone git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git a
git bisect start
git bisect good 3d77e6a8804abcc0504c904bd6e5cdf3a5cf8162
(Good: Linux 5.7)
git bisect bad b3a9e3b9622ae10064826dccb4f7a52bd88c7407
(Bad: Linux 5.8-rc1)
Download: uImage-dpaa1
Re: Kernel 5.8
This kernel does not boot!
Uboot picture: http://www.skateman.nl/wp-content/uploa ... scaled.jpg
Re: Kernel 5.8
Skateman wrote: Wed Jun 17, 2020 8:25 am This kernel does not boot!
I see. This kernel needs the boot-v1.patch because of the boot issues at the beginning of the kernel 5.8 testing.
Please try it again with the following patched kernel: uImage-dpaa2
