Kernel 5.7
Re: Kernel 5.7
Skateman wrote: Tue Apr 21, 2020 1:29 pm Kernel 5.7 RC2 running fine on my AmigaOne X5000 Fienix installation :-)
Thanks a lot for testing the RC2!
Re: Kernel 5.7
5.7RC2 up and running fine.
Re: Kernel 5.7
acefnq wrote: Wed Apr 22, 2020 12:14 pm Christian
Hi Ace,
Many thanks for testing the RC2!
Re: Kernel 5.7
Re: Kernel 5.7
Nice Patch! So only the devices available will be initialized
Re: Kernel 5.7
I released the RC3 of kernel 5.7 for the X1000 and X5000 today.
Download: linux-image-5.7-rc3-X1000_X5000.tar.gz
Screenshot of Fienix Soar PowerPC with the RC3 of kernel 5.7 on an A-EON AmigaOne X5000/40 as host and as virtual QEMU/KVM-HV guest (e5500 CPU):
@Skateman
Unfortunately I see more than 2 ethernet ports with the RC3 and Darren's patch on my X5000/40. Maybe you have an other result on your X5000/20.
Re: Kernel 5.7
Kernel 5.7 RC3 up and running on the AmigaOne X5000 using Fienix Linux!
Big picture http://www.skateman.nl/wp-content/uploa ... -40-27.png
Re: Kernel 5.7
5.7 RC3 up and running fine. Thank you.
Re: Kernel 5.7
Skateman wrote: Wed Apr 29, 2020 8:46 pm Kernel 5.7 RC3 up and running on the AmigaOne X5000 using Fienix Linux!
Great! Thanks for testing! How many DPAA network interfaces do you see with the Network Manager?
acefnq wrote: Thu Apr 30, 2020 11:33 am Christian
Thank you for testing the RC3!
Re: Kernel 5.7
xeno74 wrote: Thu Apr 30, 2020 1:11 pm
I will check this later and let you know.
The second Ethernet port on Amigakit shipped X5000 machines are unusable anyway.. There is a piece of plastic in front of that second RJ45 connector.
Nevertheless i will check.
