Kernel 5.7
daz
Re: Kernel 5.7
Post by daz »
Roland wrote: Thu May 21, 2020 7:58 pm Tested the RC6... Seems to work here, also shutdown. Only problem is that starting the onboard ethernet still needs the unplug/replug trick.
Can you test this kernel:
https://app.box.com/s/qlisrhml9flcvd7d9b0j0fagzlxhueet
Should be basically the same as Christians current 5.9 (I didn't include modules), I've just made a small change to the network options.
Note: I applied the dpaa patch but this doesn't seem to work, as the kernel only works with Fienix for me.
Darren
Re: Kernel 5.7
daz wrote: Sun Aug 30, 2020 11:29 am
Unfortunately I'm away from my X5000 during several weeks. But when I'm back I will test it.
